cam advice please
Old Nov 24, 2005 | 02:38 AM
fastfu's Avatar
Default cam advice please
i was all set to buy skunk2 stage 1 cams but now ive been offered an accord euro R head complete with cams for $600.
what would be the best option for me to go for ?
Old Nov 24, 2005 | 09:44 AM
dblock2x's Avatar
i would go with the R head
Old Nov 24, 2005 | 10:16 AM
fastfu's Avatar
Default Re: (.cooper.)
ive been doing some searching around and the accord type R make 212hp (174whp)on 11:1 compression and ive read the skunk2 stage ones will make 185whp on 10:6 compression.
can anyone confirm this ?
Old Nov 24, 2005 | 10:21 AM
mgags7's Avatar
is that head coming with the euro r intake manifold??
if so, go with that instead...
Old Nov 24, 2005 | 01:17 PM
fastfu's Avatar
Default Re: (mgags7)
yep i already have the euro manifold sitting in my garage.
does anyone have any info on what will make more power ? euro R head and cams or skunk2 stage 1's
i really need an opinion what what will make more power and i also understand that alot of people will say go with euro R just because its euro R and its rare in the states but im from the uk and euro R 's are very common here
Old Nov 24, 2005 | 01:27 PM
InvaderTrax's Avatar
Skunk2 will make more power. Just look at the cam profiles. The Skunk2 is significantly more aggressive. The R will idle smoother and be a little more streetable. That, and you can say you have a Prelude Type R
Old Nov 24, 2005 | 01:44 PM
fastfu's Avatar
Default Re: (InvaderTrax)
thanks
Old Nov 24, 2005 | 02:31 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 will make more power. Just look at the cam profiles. The Skunk2 is significantly more aggressive. The R will idle smoother and be a little more streetable. That, and you can say you have a Prelude Type R </TD></TR></TABLE>
you show me where the skunk2 is so <u>significantly</u> more aggressive....i want to see a full cam profile for both cams, and then you can point out to me which one is <u>significantly</u> more aggressive
then once you are done there, show me the dyno sheet of both cams compared on the same motor....you cannot base hp numbers solely on a spec sheet....
and if it was anything, it would be a prelude euro r
Old Nov 24, 2005 | 02:36 PM
4LugR's Avatar
Default Re: (fastfu)
i thought that the euro R cams and they type S cams were nearly identical.. and the type S cams were more agressive than the skunk 2 stg 1's... i saw a website where it had all the cam specs, and i thought that the lift on the typeS cams was equivalent of a crower 2 cam.
edit.. i found the site, here..
Stock
Specs from H22 JDM Spec Type S
Advertised Duration Duration @ .050" Gross Lift w/1.55
Int- 309 mid Int- 230 mid Int- 469 mid
Exh-315 mid Exh-230 mid Exh-438 mid
Crower 2's.
Int- 311 mid Int- 255 mid Int- 468 mid
Exh-308 mid Exh-248 mid Exh-467 mid
Modified by AEMPrelude916 at 3:46 PM 11/24/2005
tagperformance
Aug 15, 2006 09:10 AM
tomlinson619
Apr 1, 2006 12:05 AM
angela_itr
Sep 18, 2005 08:47 AM
Invisible01GSR
Aug 27, 2004 01:57 PM
