need to buy new front brake disc's.. gota question
Old Nov 23, 2005 | 05:21 PM
..::91TEG-G2::..'s Avatar
Default need to buy new front brake disc's.. gota question
im in the sponsor marketplace and i see brembo blanks, brembo cross drilled or slotted, brembo cross drilled and slotted (done by other compnay), and power slot slotted or drilled brake rotors..
now what performance (as far as braking goes) would i gain out of a cross drilled, slotted, or both rotor over the brembo blanks. is it worth the extra money to get one of the 3 different types of rotors or just get the blanks?
i heard that drilled rotors crack over time due to heat and stress, would i get the same results from rotors drilled directly from brembo and powerslot? also would i get the
same result from the brembo blanks drilled and slotted by 88brakes (or something like that in the marketplace section)?
Old Nov 23, 2005 | 05:35 PM
LSvtec03's Avatar
Default Re: need to buy new front brake disc's.. gota question (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
now what performance (as far as braking goes) would i gain out of a cross drilled, slotted, or both rotor over the brembo blanks. is it worth the extra money to get one of the 3 different types of rotors or just get the blanks?</TD></TR></TABLE>
on the street? none. most pads nowadays don't give off enough gasses to necessitate drilling or slotting. more surface area = more braking. if your car were a track *****, i might say otherwise, but i would go with the blanks. and while youre at it, check this out...
http://www.gs-r.com/phpBB2/vie...68172
Old Nov 23, 2005 | 05:37 PM
92integraVTECgsr's Avatar
just get Brembo OEM Blanks and some good brake pads (Axxis Ultimate, Metal Master, Hawk HP, HP+plus).
Old Nov 23, 2005 | 07:16 PM
NuclearB18B's Avatar
Default Re: need to buy new front brake disc's.. gota question (92integraVTECgsr)
i've got brembo blanks, axxis ultimate pads, and goodridge brake lines. well worth the 350 i spent total...
Old Nov 23, 2005 | 09:27 PM
patmcd's Avatar
Default Re: need to buy new front brake disc's.. gota question (NuclearB18B)
Unless your are tracking your car alot, just get the blanks. They are cheaper and will work just fine.
Old Nov 23, 2005 | 11:27 PM
Default Re: need to buy new front brake disc's.. gota question (patmcd)
will the brembo blanks work better than OEM that i have on there now?
Old Nov 23, 2005 | 11:39 PM
.water's Avatar
rotors are all same
OEM, Auto Zone, Brambo
Old Nov 24, 2005 | 02:06 AM
denieone's Avatar
Default Re: need to buy new front brake disc's.. gota question (zzzkangzzz)
just get the brembo blanks and if you want to do some track upgrade the pads.............
Old Nov 24, 2005 | 02:12 PM
Default Re: need to buy new front brake disc's.. gota question (denieone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denieone &raquo;</TD></TR><TR><TD CLASS="quote">just get the brembo blanks and if you want to do some track upgrade the pads.............</TD></TR></TABLE>
well i gota price of 70 shipped for a pair of front brembo blanks..
think ima go with it
pip9
44
Dec 29, 2007 01:22 PM
nowind
Oct 11, 2006 09:58 AM
DelsolioGSR1996
Sep 4, 2006 05:14 PM
prostreetonline
17
May 14, 2005 03:28 PM
ComCool
Feb 24, 2005 07:34 AM
