*Help* Boring ?.....
Old Nov 23, 2005 | 01:16 PM
RI_TM's Avatar
Default *Help* Boring b18a block?.....
Can anyone help.....
Here's the situation, I took a block to a local shop to have it bored out. (suppose to be bored out .25 = 81.25) Now the problem is that the local shop bored it 40 over...can anyone tell me what bore size it's at now? How much more will i need to bore to get it to 82mm if it's not there yet?
Sorry if it's a newbie question, just need some answers.....any help would be greatly appreciated! Thank You.
Modified by RI_TM at 10:34 PM 11/23/2005
Modified by RI_TM at 11:00 PM 11/23/2005
Old Nov 23, 2005 | 01:50 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: *Help* Boring b18a block?..... (RI_TM)
0.040" = 1.016mm
Your bore is 82.016mm.
Old Nov 23, 2005 | 02:03 PM
RI_TM's Avatar
Default Re: *Help* Boring b18a block?..... (Dogginator)
WoW.....thanks for the fast reply!
Now this leads to another thing....will this be alright for 82mm pistons? will the rings seat right? or is it o.k.?
Anyone has the charts to figure out the bore sizes? Dogginator?
Once again...thanks!
Old Nov 23, 2005 | 02:10 PM
Dogginator's Avatar
Daisy... Daisy...
I don't know what the bore tolerances are supposed to be. I am just good at manipulating units.
Old Nov 23, 2005 | 06:43 PM
RI_TM's Avatar
bump....anyone else has any clue?
Old Nov 23, 2005 | 06:51 PM
Dogginator's Avatar
Daisy... Daisy...
For the B18B1 and the B18C1 engines, the standard new bore is 81.00 to 81.02 mm. The service limit is 81.07 mm. Extrapolating from that, your 82.016 mm bore should be fine for an 82 mm piston. Do they make an 82mm piston? I've only seen the 0.25 mm overbore pistons (OEM).
raverx3m
Jun 10, 2014 10:55 AM
ludeking1007
Apr 8, 2010 09:15 AM
mugenhatchie
Apr 26, 2005 08:09 AM
vsi
Apr 30, 2003 06:35 PM
noslude93
Mar 9, 2003 07:04 AM
