Excessive Rod Sideplay...
Old Nov 23, 2005 | 11:16 AM
Phoenix1's Avatar
Default Excessive Rod Sideplay...
Ok fellas, here's the scoop: I'm assembling a B18b w/forge internals for boost, using CP Pistons and Eagle rods...the rod big end oil clearance is fine at .002", as per Eagle's spec, however, the rod has what I think is too much sideplay, i.e., the rod moves back and forth on the journal too much. I checked sideplay, and it registers .011". I checked with Eagle, whom confirmed this to be normal and within spec. Have any of you experienced this? This is the first engine I build with this much play on the rod...the machine shop checked the crank dimensions: all is ok there...any ideas? TIA....
Old Nov 23, 2005 | 06:43 PM
Phoenix1's Avatar
Pre-Thanksgiving bump....
Old Nov 25, 2005 | 10:54 AM
Phoenix1's Avatar
Default Re: (BlackPhoenix)
Post-Thanksgiving bump....anyone?
Old Nov 25, 2005 | 01:54 PM
non-VTEC's Avatar
Default Re: Excessive Rod Sideplay... (BlackPhoenix)
i do belive the side to side play is normal......there has to be some clearence for the oil to escape from the rod journal on the crank.
siblues's Avatar
I would contact earl on here he would be able to answer any questions you would have
Old Nov 26, 2005 | 11:49 AM
Phoenix1's Avatar
Default Re: Excessive Rod Sideplay... (siblues)
Yes, I know some sideplay is normal for oil evacuation on the journals, but this one seems excessive...the sideplay measurement is around .012", and from what I know this is within spec...but I'm still iffy...I'll contact earl and see what he says, thanks again.
Old Nov 26, 2005 | 04:31 PM
LudeyKrus's Avatar
Default Re: Excessive Rod Sideplay... (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i do belive the side to side play is normal......there has to be some clearence for the oil to escape from the rod journal on the crank.</TD></TR></TABLE>
If I'm thinking about this right, I agree.
There will be a bit of side to side play. It will all stay together right once bolted up and assembled, though.
If it's said to be in spec, I wouldn't worry about it at all.
Old Dec 4, 2005 | 03:00 PM
Phoenix1's Avatar
Found out what the problem was, guys: the crank was cut to compensate for a spun rod bearing, and the machine shop cut out the factory radius on the journal, thereby allowing the rod too much end play. Thanks to all who posted.
Old Dec 5, 2005 | 02:48 PM
d16dcoe45's Avatar
I don't think that is a problem at all. I am using Eagle rods on a d16a6, and the factory spec (at least for Honda rods) is 0.006"-0.012". Mine measured out as follows:
1) 0.015"
2) 0.015"
3) 0.013"
4) 0.014"
I finished building this motor about 2 months ago. Thing runs like a champ. Great oil pressure. I think of all the clearances in the motor, as long as the rod isn't binding--you are good to go. Also, this was with a standard crank that was never cut, only micropolished.
VTEC_Du_Ma_Mai
Aug 25, 2014 06:56 AM
VTEC_Du_Ma_Mai
Aug 24, 2014 07:31 PM
95dxsir2
Jan 10, 2010 02:53 PM
srmofo
Jul 20, 2009 10:59 PM
ulemu
12
Jan 3, 2006 12:37 PM
