fuel controller wiring(vtec vs non-vtec)
Is the wiring the same between the vtec and non-vtec field's fuel controllers with the exception of course of the vtec only wires. I ask because I need the non-vtec wiring diagram for an obd1 integra but no one seems to have one.
If the wiring is applicable could someone post the wiring diagram sheet.
[Modified by Muglit, 2:09 AM 3/13/2002]
If no one has the wiring diagram then could someone who has installed the field's vtec answer these questions:
1)What sensor does the "Sensor Line" refer to?
2)What is the "Speed Sensor"? Is it the VSS?
3)Is the "VTM Line" used?
