high octane
Old Mar 12, 2002 | 06:02 PM
YellowR2000's Avatar
New User
Default high octane
ok, so theres a few places here in town that sell high octane gas like 102 and 105 or so i think and my question is..how safe is this for my car, say if i used it on drag strip days, dropped a couple gallons in with some 93. do i need to do this a day or so prior to going to the strip to let my engine..i dunno..get used to it? would it be alright to put it in right before going to the strip? wiould this even be worth doing? would i notice any gains with it? what experiences have ya'll had with it? thanks for the info as usual guys...
Old Mar 12, 2002 | 06:04 PM
JohnnyBoy's Avatar
Default Re: high octane (YellowR2000)
If your car isn't detonating now...you don't need higher octane for the track. More octane just resists detonation better. Will not give you better performance.
Old Mar 12, 2002 | 06:21 PM
B2FiNiTY's Avatar
You won't need it unless you have very high compression.
Old Mar 12, 2002 | 06:52 PM
Cold Chunker's Avatar
Higher octane doesn't give you more power just because of the octane rating. Higher octane is just harder to burn than lower octane. As heat in the cylinder increases (compression, summer, etc), it's more likely that a lower octane gas will burn before the spark is fired. You get ping - knock - spark knock. Your car will retard timing to avoid that; you lose some power. The higher octane doesn't burn until the spark, so you maintain your HP. So, 92-94 ocatane is all you need unless you turn up the heat.
WarpedSportzKid
Feb 8, 2007 01:11 PM
deadline
12
Oct 12, 2006 07:50 PM
PearlWhiteAccord
Dec 11, 2003 12:13 PM
JinMTVT
Sep 12, 2001 07:58 PM
ingrate
Jul 16, 2001 06:44 PM
