questions about civic swap
Old Nov 23, 2005 | 06:30 AM
hondaman21's Avatar
Default questions about civic swap
i am about to put a d15b vtec in my 92 lx which is just a d15 right now my question is: will my stock tranny, altenator, distributor, a/c and stuff bolt to the vtec motor and anothe question i have is i will need the p28 ecu and a vtec harness right or is there more that i will need. thanks
Old Nov 23, 2005 | 03:07 PM
hondaman21's Avatar
Default Re: questions about civic swap (hondaman21)
bump
Old Nov 23, 2005 | 09:23 PM
shattered_dreams's Avatar
You will need a vtec distributer and ecu (P28)
Old Nov 23, 2005 | 09:32 PM
e jay one's Avatar
Default Re: questions about civic swap (shattered_dreams)
everything will bolt to that motor. the motor should come with a dizzy. you dont need the harness just wire the vtec yourself read the how to for a mini me same thing.
Old Nov 23, 2005 | 09:39 PM
ROK801's Avatar
Default Re: questions about civic swap (e jay one)
if dont have a vtec dizzy youll fry your ecu and if you dont have a p28, youll be running in limp mode.
Old Nov 23, 2005 | 10:55 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Yes all your AC lines will connect, like stated previously you will need other than the engine itself a 92-95 SI/EX distributor/ECU which is a P28. Or you could get the D15B corresponding ECU which is a P08 and you will not have no convert to a four wire oxygen sensor. Assuming the LX comes with a single wire oxygen sensor.
Nicaraguense13
Jan 24, 2017 01:35 PM
Dan222000
20
Feb 26, 2012 02:53 PM
mr.scruffleston
10
Oct 14, 2007 09:47 PM
no_rice_please
Feb 25, 2007 07:29 PM
zx2gotboost
Apr 23, 2006 08:20 AM
