Running your Integra without an AC Belt.....
Due to the lower temperatures now a days, I figure I wont be using my AC too much, at least till spring time. I figure if I remove the AC belt from its pulleys, it will put less strain and slightly boost the performance on my engine.
Am I correct or incorrect with my thoughts on removing the AC belt? If I do that, will I be damaging any of the components in the AC system from issues regarding the belt being removed??? Anyone with info or experience is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-nteg »</TD></TR><TR><TD CLASS="quote">a little differance... but not a noticible differance</TD></TR></TABLE>
So removing the AC belt is pointless? Or could I benefit from it enough to take it ofF?
you wont damage anything by taking the belt off.
performance increase would be negligible imo. the slightly noticeable gains would be from weight reduction - if you took the compressor and connecting components out imo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecriver »</TD></TR><TR><TD CLASS="quote">it will make no difference at all the pulley pretty much spins freely when the AC isnt on, so just keep the belt on.</TD></TR></TABLE>
So the resistance applied to the crankshaft pulley from the AC belt is close to nothing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">
So the resistance applied to the crankshaft pulley from the AC belt is close to nothing?</TD></TR></TABLE>yepidydo
The A/C compressor pulley uses a clutch system so that the compressor only works (and puts a load on the engine) when the A/C is turned on. When off, the A/C compressor pulley puts no more load on the engine than does the free-spinning A/C tensioner pulley.
I would not take the belt off, as there are many times in winter where I need the A/C (blowing warm conditioned air) to clear my windshield.
Removing the power steering belt would make more of a difference in freeing up engine power than would removing the A/C belt. However steering will be extremely heavy and a PITA unless you rig up one of those P/S removal kits that a couple of H-T members sell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">The A/C compressor pulley uses a clutch system so that the compressor only works (and puts a load on the engine) when the A/C is turned on. When off, the A/C compressor pulley puts no more load on the engine than does the free-spinning A/C tensioner pulley.
Removing the power steering belt would make more of a difference in freeing up engine power than would removing the A/C belt. However steering will be extremely heavy and a PITA unless you rig up one of those P/S removal kits that a couple of H-T members sell.</TD></TR></TABLE>
Thanks Patrick and all others who contributed to this topic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg »</TD></TR><TR><TD CLASS="quote">I just removed my AC. No point of just taking off the belt. I probably droped like 25-30lbs by emoving my AC. </TD></TR></TABLE>
u wanna give a little walkthrough of all the **** u removed? i'm interested in doing it as i've gutted everything else i might as well do this too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 »</TD></TR><TR><TD CLASS="quote">
u wanna give a little walkthrough of all the **** u removed? i'm interested in doing it as i've gutted everything else i might as well do this too.</TD></TR></TABLE>
AC Condenser
AC Compressor
AC Belt
Dryer + connecting lines running down and across the front bumper area, in front of the condenser
AC Lines running in the engine bay, starting with Line A at the compressor.
Once disconnected from the Evaporator (Underneath the dash), either plug the hole with the Integra RS rubber plug that goes in place of the ac lines, or go all out and get the Integra RS evap. box and heater box to convert it to the no AC interga RS style.
AC Condenser
AC Compressor
AC Belt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Platinum Playa »</TD></TR><TR><TD CLASS="quote">don't even bother taking it off, u want to free up some horsepower, its basically winter time man who cares.</TD></TR></TABLE>
Agreed...the question is more staged than anything. I'm actually trying to prove a point to someone who had told me removing the AC belt made a "Night and Day" difference. Thanks everyone, again.
AssPenny
Jun 3, 2002 09:57 AM
