D15B2 coolant hoses on a B16 Si motor...SAME?????(88-91Civic)
Old Nov 23, 2005 | 04:37 AM
Civiclized's Avatar
Default D15B2 coolant hoses on a B16 Si motor...SAME?????(88-91Civic)
Just like it says, are these interchangable?
Thanks for any useful feed back
Old Nov 23, 2005 | 07:34 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: D15B2 coolant hoses on a B16 Si motor...SAME?????(88-91Civic) (Civiclized)
The curved hose between the intake and thermostat housing is..
Check here for a B16 parts list:
https://honda-tech.com/zerothread?id=1024595
Old Nov 23, 2005 | 11:30 AM
phatrick2332's Avatar
Im guessing you already have the d15 parts, so why not go out to your car and see if they work?
Old Nov 23, 2005 | 02:28 PM
tangerinebeast's Avatar
i believe they will work but you will have to pry them onto the thermostat houseing and onto the coolant return one because the hoses are smaller in diameter if you use a ls one from lik a 90-91 then they will fit on the motor fine but will need a tightenable clamp instead of the factory one
dirtygerman
Apr 28, 2013 04:43 AM
lee0149
15
Feb 24, 2009 04:42 PM
DOHC4banger
Apr 17, 2008 05:26 PM
ttracing03
Oct 3, 2006 05:18 PM
reek
Jul 5, 2005 09:54 PM
