My CRX is a DOHC ZC w/ZC tranny, its a DX, what was replaced to fit it?(hubs, ect?)
Old Nov 23, 2005 | 01:47 AM
EKCRX-Ihadastupidusername's Avatar
Default My CRX is a DOHC ZC w/ZC tranny, its a DX, what was replaced to fit it?(hubs, ect?)
What is needed to fit the ZC tranny into a 91 DX? As far as I know, only the Si can bolt in the ZC tranny with no mods, like knuckles, hubs, brakes, ect.
My car has the DOHC tranny, cause I got under it and it has the intermediate shaft and 2 short axles. I'm guessing something had to be changed? Mine is a DX.
If you wonder why I ask, the **** was swapped already, so I wouldn't know what had to be changed, this was not a swap I had to research.
Reminds me, I need to check for a LSD.
Old Nov 23, 2005 | 01:56 AM
punkdown's Avatar
Default Re: My CRX is a DOHC ZC w/ZC tranny, its a DX, what was replaced to fit it?(hubs, ect?) (diegoaccord
Nope, Si and DX have the same hubs and stuff, it's only the HX's that need to be replaced.
Old Nov 23, 2005 | 01:59 AM
crxnj's Avatar
I think you mean HF and std need to be replaced..
Old Nov 23, 2005 | 02:02 AM
punkdown's Avatar
He said CRX, there is no STD CRX.
Sorry I probably sound like a dick there. I only mentioned the HF because we were refering to CRX's, but you are correct about the Civic std.
Old Nov 23, 2005 | 02:06 AM
crxnj's Avatar
Yeah I know..But you put hx..
Std = hf hubs anyway..
Old Nov 23, 2005 | 02:09 AM
punkdown's Avatar
Doh, I missed that. My bad.
Old Nov 23, 2005 | 02:16 AM
Okay.
Well, that makes me think. Can I use the front brakes off my EJ1? Integra sized 94+ spec.
Old Nov 23, 2005 | 06:00 AM
Kwicko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkdown &raquo;</TD></TR><TR><TD CLASS="quote">He said CRX, there is no STD CRX.
Sorry I probably sound like a dick there. I only mentioned the HF because we were refering to CRX's, but you are correct about the Civic std.</TD></TR></TABLE>
Sorry, but there IS an Std. CRX, at least according to my Honda Factory Service Manuals. They refer to the mid-line model as both the DX *AND* the Std.
But yeah, if your CRX is a DX (or Std), then you didn't have to replace the hubs. About all you'd have to do to get a DOHC ZC engine and ZC tranny in the car would be the DPFI-to-MPFI swap and use a ZC-compatible ECU.
Mike
Old Nov 23, 2005 | 06:22 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwicko &raquo;</TD></TR><TR><TD CLASS="quote"> About all you'd have to do to get a DOHC ZC engine and ZC tranny in the car would be the DPFI-to-MPFI swap and use a ZC-compatible ECU.
Mike</TD></TR></TABLE>
and ZC intermediate shaft with 90-93 Integra axles
Old Nov 23, 2005 | 06:25 AM
mike-y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diegoaccord &raquo;</TD></TR><TR><TD CLASS="quote">Okay.
Well, that makes me think. Can I use the front brakes off my EJ1? Integra sized 94+ spec.</TD></TR></TABLE>
not without replacing the front knuckles/hubs. You need either 90-93 integra (very slightly length difference), SiR, or 90-91 civic EX knuckles/hubs to fit those brakes.
Old Nov 23, 2005 | 06:30 AM
4DRmafia's Avatar
what if u had a si tranny can u still use the si axles?
Old Nov 23, 2005 | 06:54 AM
jlicrx's Avatar
Default Re: (SkipMic2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">what if u had a si tranny can u still use the si axles?</TD></TR></TABLE>
yes - Si or DX
Old Nov 23, 2005 | 03:36 PM
Default Re: (jlicrx)
Yeah it's all complete and ****. Sadly running a PM6. I'm gonna be looing into a PG7/PR3/PR4/PM7
silver hatch
13
Mar 19, 2005 08:09 PM
jadugartir
Sep 10, 2004 11:43 AM
nuc79
Aug 14, 2003 09:33 AM
TheBlackCrx
Apr 10, 2003 05:57 PM
civickidd99
Dec 22, 2001 06:51 AM
