215/45/17
Old Nov 22, 2005 | 10:13 PM
zexifiedlude's Avatar
Default 215/45/17
hey, ok i had 215/40/17 size tires all around but couple days ago i blew my right front tire on the side and couldnt get it repaird. so intsead of buying a new one i took my friends pair of 215/45/17 khumo's he had laying around. i got the rear wheels put up front and put the bigger ones in the back.. but for some reason only the rear right tire rubs when i hit a bump or something, and the left is perfectly fine.. what can be causing this?
Old Nov 22, 2005 | 11:45 PM
DLudist's Avatar
is it lower on that corner? maybe tire pressure or something. i dunno
Old Nov 23, 2005 | 03:54 AM
MadCityLude
Guest
Posts: n/a
Default Re: (DLudist)
frame could be tweaked!
Old Nov 23, 2005 | 05:09 AM
britishlude's Avatar
Default Re: 215/45/17 (zexifiedlude)
Might be good idea to have an alignment check, to see if the wheel is leaning in or out slightly.
Old Nov 23, 2005 | 10:56 AM
4LugR's Avatar
Default Re: 215/45/17 (britishlude)
well, i have 215-45 17 on my car, and they rub in the front, only when i turn hard. my car isnt even that low.. but my rears dont rub, so alignment check time..
Old Nov 25, 2005 | 09:17 AM
if i were to get new 16 inch wheels instead of 17 inch... would 215/45/16 be the same as 215/40/17
Old Nov 25, 2005 | 10:03 AM
96SR-V's Avatar
Default Re: (zexifiedlude)
exact same thing happened to me last year, I hit a raised sewer and busted my front tire they were 215/40/17 now I have 215/45/16's and its a much nicer ride, falken make the azenis in this size tires are great on dry roads. I really ejoy this combo much more then the 17" setup. corners better, acceleration is much and the ride is much smoother over bumps. I really like it... wouldn't go back now.
Integra21
Jun 23, 2005 09:18 PM
lodown414
Nov 4, 2002 10:11 PM
Doogie Howser
Jun 24, 2002 05:34 AM
SuperRice
Mar 5, 2002 09:18 AM
