suspension help!
Old Nov 22, 2005 | 09:52 PM
all_motor's Avatar
Default suspension help!
I recently changed my axles and now it looks like the frame isnt straight. Before I changed the axles, the frame wasnt like this. Does anybody know why? I had to change the drivers side control arm along with it because of a messed up lower ball joint and I had a new lower ball joint replaced on the passenger side. The passenger side is sitting like a half inch or an inch lower than the drivers side.
Old Nov 23, 2005 | 01:26 AM
all_motor's Avatar
Default Re: suspension help! (all_motor)
anybody...?
Old Nov 23, 2005 | 01:28 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Changing your axles will do nothing to the frame. Changing the lower control arm might be your problem. Are you sure you put one on that isn't bent?
Got pics?
Old Nov 23, 2005 | 02:21 AM
all_motor's Avatar
Default Re: suspension help! (JDM_Ej)
Im not sure if the arm was bent or not. I got that arm from a friend of mine because he swapped his suspension out for gsr suspension. Im pretty sure it's straight. If that's the problem then I probably am going to have to get my old one out of the trash can. I dont have any pics at the moment, but it kind of pisses me off looking at my car and she's sitting like that.
DeSerees
Dec 9, 2016 11:20 AM
igorka_91
Mar 15, 2010 02:33 PM
stiles_EG6
Dec 14, 2009 03:14 PM
detuned
Jul 7, 2009 03:47 PM
17
Oct 2, 2006 08:58 PM
