head lights & brake lights dont work
Old Nov 22, 2005 | 09:23 PM
mckenzie's Avatar
Default UPDATE passenger headlight dont work
the head lights dont turn on [new bulbs, previous owner had projector lights, they are oem now]
tail lights dont work [w/switch on or while the pedal is being pressed]
cluster doesnt light up.
only lights that work is hazards
left and right blinkers [left one sometimes does not want to work]
reverse lights work.
dome light
fuses look good. i dont have the correct fuse maps for the dash nor under the hood.
Modified by superpho at 5:10 PM 12/27/2005
Old Nov 29, 2005 | 02:56 PM
project_K's Avatar
Default Re: head lights & brake lights dont work (superpho)
look at all connectors on wheel. make sure all clips are plugged in. look on break pedal. there is a sensor. when the brake is not in use the little black button on the end of it should be in. brake lights come on when its out. may need adjust. make sure clip is in the end of it. (a bitch. tight area). n dash lights. talk cluster out look at all clips. also pull out all bulbs in cluster n make sure not blown. i met my girl workin on her car bc some dumb *** jumped her car neg-pos, pos to neg. n thats what happen to hers. blew her dash lights. strange ****. does your tach n speed work? if it does check bulbs n connectors. WATCH OUT FOR THE YELLOW WIRE!!!!!! AIRBAG!!!!!!
Old Dec 27, 2005 | 04:09 PM
mckenzie's Avatar
Default UPDATE
i fixed the problem with the lights they all seem to be working except the passenger side head light and the driver side corner light.. i triple checked the wiring. switched bulbs [neither one is blown.]
if anyone has a picture of their fuse map under the dash and could snap a couple pics for me that would help..and the fuse map under the hood also. thanks
thebestwade
May 4, 2017 03:29 PM
Dudun
Honda Civic (2001 - 2005)
Mar 22, 2008 03:50 PM
Convoy
Feb 18, 2008 02:40 PM
2f2fLOL
May 23, 2007 09:50 AM
NatedoggAZ
Feb 10, 2006 11:00 AM
