Timing belt question
Old Nov 22, 2005 | 08:23 PM
codemaster63's Avatar
Default Timing belt question
I am about to get my timing belt and balance sheft belt replaced by my a coworker. I went and showed him my 98 accord i-4, and he said I still needed to get a timing belt tensioner and an idler pulley. The timing belt tensioner was easy for me to purchase online, but the idler pulley was still unwilling to be located on the internet. I went to my local Honda dealership and purchased an idler pulley, although they said some people called them other names. Anyways I went onto an Accord parts site and I noticed a part on their site called a balance shaft tensioner, and it looked very familiar to my idler pulley I purchased at the dealership except half the price. My question is are these the same parts? I have no knowledge of what an idler pulley is, and is it the same thing as a balance shaft tensioner?
Old Nov 22, 2005 | 08:40 PM
P_Adams's Avatar
Default Re: Timing belt question (codemaster63)
Isn't this a duplicate from a thread from yesterday?
Like this one.....
https://honda-tech.com/zerothread?id=1441345
Old Nov 23, 2005 | 08:04 AM
alotawatts's Avatar
Can't your coworker help ? Has he done a Honda before ?
Old Nov 23, 2005 | 12:39 PM
hondadude's Avatar
http://www.cybertrails.com/~pu....html
Read this webpage so you can be sure the job is done right
Old Nov 23, 2005 | 05:35 PM
Honda-Master's Avatar
don't replace tensioner or idler pulley unless they are noisy. ..it is not necessary to replace them
Old Nov 23, 2005 | 07:13 PM
CRXb18Turbo's Avatar
Default Re: Timing belt question (Honda-Master)
Don't forget the waterpump
Modified by CRXb18Turbo at 11:11 AM 12/3/2005
Old Nov 26, 2005 | 02:50 PM
KevinCruz's Avatar
Default Re: Timing belt question (CRXb18Turbo)
dont also forget to get valve cover gasket, tube seals, cam seal, crank seal, and balancer seal. there is also a balancer shaft seal retainer you can purchase from a honda dealer. honda had a problem with balancer shaft seals popping out on the older honda. so whenever i do a t-belt on a four cylinder accord i install that balancer shaft seal retainer.
Alan Roberts
Dec 10, 2018 08:05 PM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
codemaster63
Nov 21, 2005 02:35 PM
stevescivic
Aug 25, 2004 10:14 AM
PrecisionH23a
Aug 14, 2002 05:16 AM
