TEG brakes on my wagon and now I have no peddle
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
well i just put on some da TEG front brakes and 91 prelude master cylinder and bled them and the peddle drops to the floor when i press it. am i missing any thing? parts i may need? help help i need my vtec back
Modified by 1QwIkEf at 4:52 AM 11/23/2005
yeah, either
a. there's air in there, or
b. the master cylinder's toast.
if there's air in there, did you bench bleed the master cylinder? are there any leaks (coming out of the pistons, brake lines attached (duh, but i've found i make the dumbest mistakes sometimes) bleeders tight, etc.
no i didn't do that. its doing the same thing i was b4 i put the 15/16 m/c on. it thought the stock 13/16 wasn't big enough so i swapped it
Then bench bleed it, re-bleed all the lines and u should be set. And the stock 13/16" M/C works with the teg front brakes.
i have the 88-91 prelude m/c its the same as the 4 door ex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akiraboy »</TD></TR><TR><TD CLASS="quote">http://www.scirocco.org/faq/br....html</TD></TR></TABLE>
Great info
Great info
ok i did the bench bleed and it helped a little. any one know if it will do this if i still have the civic brake lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf »</TD></TR><TR><TD CLASS="quote">ok i did the bench bleed and it helped a little. any one know if it will do this if i still have the civic brake lines.</TD></TR></TABLE>
The Civic brake lines work fine. It sounds like there is still air in your system. How are you bench bleeding it?
what my dad did on his car - a 1969 chevy camaro w/ corvette discs in back and front - he let the master cylinder cover off w/ brake fluid in it. He also left two bleeders open over night and that helped get the air out.
You could try that, but it might not have an effect on hondas.
A brake system is a brake system though. They are pretty much the same.
-Jon
-Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy »</TD></TR><TR><TD CLASS="quote">what my dad did on his car - a 1969 chevy camaro w/ corvette discs in back and front - he let the master cylinder cover off w/ brake fluid in it. He also left two bleeders open over night and that helped get the air out.
-Jon</TD></TR></TABLE>
Sounds like gravity bleeding.
1QwIkEf
Suspension & Brakes
24
Nov 29, 2005 01:22 PM
y49crxsi
Jul 16, 2004 02:14 PM
model x
19
Nov 3, 2002 10:19 PM
