P28 ON B18
Old Nov 22, 2005 | 05:54 PM
ThatsMyEG's Avatar
Default P28 ON B18
Will a non chipped p28 work on a ls/vtec setup??? will vtec actually kick in?
Old Nov 22, 2005 | 06:36 PM
solk1dd's Avatar
ya it will probably work but i wouldn't recommend it.
Just get it chipped, instead of putting your motor at risk.
Old Nov 22, 2005 | 06:56 PM
neutron91's Avatar
Default Re: (solk1dd)
yeah it will work... had a few friends do this until they could afford to get it chipped and so forth
Old Nov 22, 2005 | 07:48 PM
jdmcars.com's Avatar
Default Re: P28 ON B18 (ThatsMyEG)
The P28 will control the VTEC, however the fuel mapping is not correct. It would be best to get the car on a dyno and have some tuning done with the P28 to get the correct curves.
If that is just to much to spend at this time, it would be at least a good idea to have the P28 with a generic standard chip for a base line program of a LS/VTEC step up. Not that it would be as sgood as one done per your set up, but even a closer map would be better than a stock P28 for your setup.
Thump_eg94
Jun 25, 2010 12:37 PM
madcrx69
Engine Management and Tuning
Jul 21, 2009 08:42 AM
Ls_Turboteg
Dec 10, 2008 07:10 PM
redline23
May 7, 2004 06:10 AM
