b16 crx si vaccum diagram
Old Nov 22, 2005 | 04:35 PM
teler86's Avatar
Default b16 crx si vaccum diagram
hey guys i have a quick question if anyone has any pictures or diagrams or can just explain to me how to wire in the vaccume lines on my car. I have a b16a with an ITR intake manifold and throttle body, and i cant find any diagram to exactly match my set up. als as an aside what is the plug for on top of the ITR throttle body?
Old Nov 22, 2005 | 05:15 PM
88YellowRexSi's Avatar
Default Re: b16 crx si vaccum diagram (teler86)
if your talkin about the black peice on top of the TB that has a three wire socket would be....the MAP sensor. CRX's have the map sensor mounted to the firewall along with one or two vacuum solenoids (depends on the year). You can either use it or use the factory one. I am pretty sure the plugs are different so just use the factory one. Here's a vacuum diagram:
Hope it helps...
Old Nov 23, 2005 | 02:45 AM
teler86's Avatar
Default Re: b16 crx si vaccum diagram (88YellowRexSi)
my intake manifold and TB are from an ITR and dont have 1/2 of those leads. I will try to take a picture for claification
Old Nov 23, 2005 | 06:48 AM
Chase's Avatar
All you need is the FPR vaccum, which is right on the IM. And plug in your map sensor on top of the throttle body and ur done. You dont need any of the stuff that sits on the upper firewall anymore!!
You dont need the charcoal canister either unless u have emissions. Just plug off any unused ports. I beleive there will be one on the back of the ITR IM.
Old Nov 25, 2005 | 05:58 AM
teler86's Avatar
Default Re: b16 crx si vaccum diagram (EF8kid)
the crx wiring harness does not have a plug for an electronic map sensor
Old Aug 21, 2006 | 10:16 PM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid &raquo;</TD></TR><TR><TD CLASS="quote">All you need is the FPR vaccum, which is right on the IM. And plug in your map sensor on top of the throttle body and ur done. You dont need any of the stuff that sits on the upper firewall anymore!!
.</TD></TR></TABLE>
this is the way mine setup is working,
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
b16powwer
Aug 6, 2002 08:08 PM
spettinger
Jul 9, 2002 04:11 PM
spettinger
Jul 9, 2002 02:14 PM
spettinger
May 21, 2002 02:18 PM
