CRX stuttering bad from 0-25mph...?
Guest
Posts: n/a
my 1990 crx dx with a d15b2, dpfi has a real bad stuttering problem from 0-25mph. its really annoying and this is my daily driver. im lost as to what is causing it.
this is what ive replaced so far.
spark plugs
plug wires
dist. cap/rotor
fuel filter
injectors
headgasket set
air filter
o2 sensor
iat sensor
timing is dead on and idles fine
spark plugs
plug wires
dist. cap/rotor
fuel filter
injectors
headgasket set
air filter
o2 sensor
iat sensor
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">if you know someone with a matching dist. then try it.</TD></TR></TABLE>
no i dont.... what exactly could be wrong with the dizzy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">
no i dont.... what exactly could be wrong with the dizzy?</TD></TR></TABLE>
if it's going out, the car will misfire and and stumble, especially at low rpms.
What kind of intake manifold do you have my buddy had one just changes yesterday. It was studding and jerking so he did everying even put another motor in his car but use the same intake manifold and it still had the same promblem so he change intake manifold and it runs perfect now.
yeah, bubles in the coolent causes suttering, The bubles get wraped around the sensors. I had the same problem as you, and bleeding the Coolent system correctly fixed it.
you sure it's .3? i thought it was 350-550 ohms, helms manual says to replace the distributor if it's not inbetween those. mine was 373 and there was no continuity so i have a bad wire somewhere...sucks not driving the crx.
edit:fixed my resistance number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">yea but if the sensors werent working right then i would get a CEL. and besides what sensors that come in contact with coolant can cause stuttering??</TD></TR></TABLE>
wrong, IACV I think it is called. Mine had no CEL.
Form all my past honda experiences, stuttering has been due to ingition related problems. Usually bad wires, plugs or coil.
Just because youve changed something... dont rule it out... ,Ive seen it lots where the new parts installed are bad.
Usually ingition problems happen at lower rpm's... and after the rmp's are raised... it is not as notceable.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaFawnduh »</TD></TR><TR><TD CLASS="quote">wrong, IACV I think it is called. Mine had no CEL.</TD></TR></TABLE>
you said sensors. IACV is a valve, not a sensor..it has no wires going to it.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotboxedcrx »</TD></TR><TR><TD CLASS="quote">Form all my past honda experiences, stuttering has been due to ingition related problems. Usually bad wires, plugs or coil.
Usually ingition problems happen at lower rpm's... and after the rmp's are raised... it is not as notceable.</TD></TR></TABLE>
yes but basically what i need to know now is can a coil cause stuttering at low rpms? ive always though that they either work or they dont..
btw, the haynes manual says if its not 0.3-0.5 then to replace the coil...but before i go and waste $50 on a new one, i want to kinda make sure that the coil can cause my problems..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">you said sensors. IACV is a valve, not a sensor..it has no wires going to it.</TD></TR></TABLE>
wow, you are one picky *****.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaFawnduh »</TD></TR><TR><TD CLASS="quote">wow, you are one picky *****.</TD></TR></TABLE>
excuse me! im not being an *** or *****.
you said sensors, then i said i would get a CEL..since the CEL comes from sensors, then you said IACV, then you said i was wrong about saying i would get a CEL from sensors, then you call me picky *****.
GTFO
GTFO
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjdmb16a »</TD></TR><TR><TD CLASS="quote">I had the same **** happen on my d15 dpfi, it was the dizzy so junked that engine! Change that ****</TD></TR></TABLE>
what specifically about the dizzy, you know?
