92 hatch wont start
ok..this problem started last thursday
my hatch just wont start
it cranks but doesn't start
i changed the distributor, checked the starter relay and switched it, and even used a new ECU
i have a d16z6 turbo by they way
the car started today and i drove it for about 5 minutes and it died on me...try to start it back up and it just dies after about 1/2 second
it seems like there isn't enough gas, or there might not even be any fuel gettin pumped into the engine
any advice would help
thanx
thanx
sounds like you on the right track
you need 3 things. spark, air, gas.
check for spark, 1 spark plug at a time. make sure they are all good.
im sure you have air unless your air filter is just clogged to sh*t
loosen the hose connected to the fuel rail that runs to the filter. stick a rag underneath it and put the key in the on position. check the rag for fuel.
are you sure its not flooded. to much fuel. if so remove the fuel pump relay and crack it over a couple times. then plug the relay back in
platinum.
platinum.
hondabro1988
Jul 31, 2012 02:55 PM
nookers
Apr 1, 2004 07:23 PM
