Cruise Control
Old Nov 22, 2005 | 02:22 PM
JdmB16Eg6's Avatar
Default Cruise Control
I know that there are alot of threads but most of them seem to end up nowhere. ive went through 4 pages of threads but still have a question. One of my vaccum lines from the CC to the Intake mani is disconnected . My question is, if one vaccum line is disconnected, will it not make the cruise control activate. my light comes on but it doesnt hold its speed. i check the brake and gas assembly but it looks normal to me. i have also tried finding the nipple to the intake mani but im using a CTR mani so i believe it doesnt have one. im sure i can tap into one but im not sure that is the only thing holding it back. thanks in advance
Old Nov 22, 2005 | 02:36 PM
JdmB16Eg6's Avatar
Default Re: Cruise Control (JdmB16Eg6)
TTT
Old Nov 22, 2005 | 02:47 PM
nub's Avatar
nub
yea you can just tap into another vac. line, also if this is factory cruise there is a small check valve on the line make sure the arrow points away from the engine
Old Nov 22, 2005 | 03:48 PM
JdmB16Eg6's Avatar
Default Re: Cruise Control (nub)
thanks, but what would the check valve represent?
Old Nov 22, 2005 | 03:57 PM
JdmB16Eg6's Avatar
any other ideas
Old Nov 22, 2005 | 08:07 PM
EG2Driver's Avatar
Default Re: (JdmB16Eg6)
bump for an answer
Old Nov 22, 2005 | 08:33 PM
Relic1's Avatar
from my understanding on how it works... the stock cruise setup uses a vacuum pod mounted in the drivers fender well (under the splash guard) that stores vacuum to be used in case of WOT conditions.
the check valve is there to prevent vacuum loss from this pod.
Old Nov 23, 2005 | 06:53 PM
JdmB16Eg6's Avatar
Default Re: (Relic1)
so vaccum is just there under WOT conditions, so basically that's not my problem then right, i am probably not checking all the wires correctly
Old Nov 25, 2005 | 11:04 PM
JdmB16Eg6's Avatar
right??
Old Nov 26, 2005 | 10:50 AM
Relic1's Avatar
the pod is there to supply vacuum only under WOT conditions. any other time the engine supplies enough vacuum to keep it working.
EJ8_Man
Jan 18, 2011 08:55 PM
Happy Gilmore
Nov 7, 2008 08:15 AM
obuhmyuh
Jun 7, 2008 06:43 PM
b18cEK
20
Jun 21, 2005 10:29 AM
AccordRacing
May 27, 2005 05:42 AM
