Antifreeze leak under car
Hi, recendly my car been leaking Antifreeze wright under the water pump and belt pulley. I have a H22 engine and I am not sure if it's the waterpump. If anyone has experience a similar situation. Please, let me know what can I do to fix the problem.
you shouldn't be able to see the water pump just by popping the hood or looking uderneath your car. the water pump is located down by the crankshaft, behind a plastic cover, unless you have removed the cover for some reason. is the pump you are thinking of in front, kind of by the headlight? there should be 3 things in that area: the power steering pump is on top, under that is the alternator, and at the bottom is the AC. find out which one has the leak (cannot be the alternator, theres no liquid invloved), and let me know.
kwizzman
Honda CR-V & Element
11
Dec 21, 2021 12:33 PM
Mrob91GS
Mar 26, 2005 08:25 AM
RedRyda
Jun 16, 2004 04:41 PM
