My slightly screwed engine.....greatest 98,000 miles of my life
Old Nov 22, 2005 | 12:59 PM
Jowee's Avatar
Default My slightly screwed engine.....greatest 98,000 miles of my life
Cordillia had her last event this weekend on her stock engine at 98,000 miles. On Sunday after the 2nd heat, I noticed a knocking coming from the engine right after my instructer soloed me
So onto Migs trailer she went back to my house. Last night I ripped out the engine to find this.
I think that's just because of the coolant that got sucked in due to the crappy ANR intake mani gasket -> https://honda-tech.com/zerothread?id=1427724
A little bit of carbon build up.
After pulling the rods/pistons out, I noticed the OEM hash marks were still there with no damage on the walls.
Anyone spot the problem?
On top of that, some of my piston ring on cylinder 1 fell out.....
Here's a little bit of gold flake I found in the oil pan
I got off the phone with Len a minute ago and hopefully the rebuild will run me barely under $500.
Any advice or tips would be appreciated
Old Nov 22, 2005 | 01:06 PM
jakeiscool's Avatar
Banned
Default Re: My slightly screwed engine.....greatest 98,000 miles of my life (Jowee 1162)
buy an h22 to replace it.
Old Nov 22, 2005 | 01:09 PM
Dave-ROR's Avatar
Default Re: My slightly screwed engine.....greatest 98,000 miles of my life (JakeIsCool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool &raquo;</TD></TR><TR><TD CLASS="quote">buy an h22 to replace it.</TD></TR></TABLE>
Why bother? That C5 would keep the car in a numbers matching state and looks to be easily fixable from the pics.
Are H22's already down to $500 for the whole swap? if not it'll be more expensive to lower the resale value to boot.
Old Nov 22, 2005 | 01:10 PM
Opie's Avatar
Sorry Joe E
Rebuild
Old Nov 22, 2005 | 01:15 PM
Kendall's Avatar
Well ****. Good luck on the overhaul.
Old Nov 22, 2005 | 01:26 PM
splitime's Avatar
Default Re: (Kendall)
Get the crank inspected/measured (or Mic it yourself). Just make sure the crank will be ok... if so, the normal hone/ring/bearings should do the job
Old Nov 22, 2005 | 01:48 PM
typer_696's Avatar
Default Re: (splitime)
rebuild it on get on the road again.
Old Nov 22, 2005 | 03:55 PM
kepani's Avatar
Default Re: (neo_)
sorry to hear jowee... reincarnation means that sometimes you come back even faster and stronger!
kepani
Old Nov 22, 2005 | 04:09 PM
white rocket's Avatar
Default Re: (kepani)
sounds you had a good run with the stocker. Time to rebuild bigger, better and badder. *cough, ehem, 2.0L cough, cough*
Old Nov 22, 2005 | 06:07 PM
Chris F's Avatar
Default Re: (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote"> *cough, ehem, Turbo cough, cough*</TD></TR></TABLE>
Just kidding.
Motorsport ranch is pretty fun, sucks to have motor problems.
Occasionally, I have doubts about Honda reliability. Thank god these aren't German cars.
Old Nov 22, 2005 | 06:09 PM
Reid's Avatar
Global Moderator
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Occasionally, I have doubts about Honda reliability.</TD></TR></TABLE>
Is this before or after you gave the car more than double the hp it came from the factory with?
Old Nov 22, 2005 | 06:14 PM
Chris F's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Is this before or after you gave the car more than double the hp it came from the factory with? </TD></TR></TABLE>
Mostly after.
Old Nov 22, 2005 | 06:50 PM
Shawn C's Avatar
In The Garage
i might suggest going with a .25mm (.010") overbore, with some ctr oversized pistons, so the cylinders are round again (they become ovular over time).
also check to make sure that the crank is still perfect. many times, when you hear a rod knocking, you have partially spun a bearing. this will normally mess up a rod journal on the crank, and even screw up a rod.
Old Nov 22, 2005 | 07:14 PM
Haleiwa-Brando's Avatar
Default Re: (ShadyEH2)
How about since you have this thing apart, why not replace the OEM parts with forged internals? Then you can really beat on it, with less worry. This makes absolute and complete sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">*cough, ehem, sleeved block, forged internals cough, cough*</TD></TR></TABLE>
Old Nov 22, 2005 | 07:35 PM
97 TYPE-R 312's Avatar
Default Re: (Haleiwa-Brando)
Get her back on track y0!
-Victor
Old Nov 22, 2005 | 07:39 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">How about since you have this thing apart, why not replace the OEM parts with forged internals? Then you can really beat on it, with less worry. This makes absolute and complete sense.</TD></TR></TABLE>
Yeah, sleeving a block and putting in forged pistons and rods is a no-worries proposition. Right Brandon?
My sarcasm detector has been flaky.... you'll have to let me know if you're kidding or not
Old Nov 22, 2005 | 07:42 PM
My sarcasm detector has been flaky.... you'll have to let me know if you're kidding or not </TD></TR></TABLE>
I'm laughing at you, but am serious about my comment on forged internals. You and I both know first hand (more than once) the benifits of forged internals.
Old Nov 22, 2005 | 07:45 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">I'm laughing at you, but am serious about my comment on forged internals. You and I both know first hand (more than once) the benifits of forged internals.</TD></TR></TABLE>
We know about the pitfalls of boosting with stock internals, that's for sure
-Chris
Old Nov 22, 2005 | 07:47 PM
Bbasso's Avatar
I'm in the same boat as you...
Sorry to hear of the headache, good luck!
I bet if I open my motor right now, it look like yours. But I am looking into warranty options at this point. Blowing it up was pretty cool tho. I thought I would be all upset and worried
&lt;--- Speaking from a comfy state of mind
Old Nov 22, 2005 | 07:50 PM
Chris F's Avatar
Default Re: My slightly screwed engine.....greatest 98,000 miles of my life (ossabB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ossabB &raquo;</TD></TR><TR><TD CLASS="quote">&lt;--- Speaking from a comfy state of mind </TD></TR></TABLE>
South Carolina?
Drunk?
-Chris
Old Nov 22, 2005 | 07:52 PM
-Chris</TD></TR></TABLE>
Forged Internals&gt;****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ossabB &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the same boat as you...
When did your engine pop?
Comfy state of mind?...what's going on...
Old Nov 23, 2005 | 04:34 AM
ITRbroham's Avatar
shit post warrior
Default Re: My slightly screwed engine.....greatest 98,000 miles of my life (Haleiwa-Brando)
98K miles on the original motor? Consider yourself lucky taking into account the way ITR owners drive their cars.
Old Nov 23, 2005 | 05:10 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ossabB &raquo;</TD></TR><TR><TD CLASS="quote"> But I am looking into warranty options at this point</TD></TR></TABLE>
Doesnt the dealer get tired of that?
Old Nov 23, 2005 | 05:47 AM
Dave-ROR's Avatar
Default Re: My slightly screwed engine.....greatest 98,000 miles of my life (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Doesnt the dealer get tired of that?</TD></TR></TABLE>
What if it's the dealer that suggests using warranty?
Old Nov 23, 2005 | 05:51 AM
Dave_B's Avatar
Share fool, share. How's Brad's place? Any word on when you guys will have it back to stock?
