brake squeak diagnosis
Old Nov 22, 2005 | 11:51 AM
ebonyrolla7's Avatar
Default brake squeak diagnosis
I know that this is probly an obvious question but my rear right brakes is squeking so do i need to replace pads and rotors....or is it just case sensitive? thanx
Old Nov 22, 2005 | 11:53 AM
...rohit's Avatar
Default Re: brake squeak diagnosis (ebonyrolla7)
are they drum brakes in the rear? if so they may just need cleaning. if not its most likely your pads. while replacing your pads i would get the rotors resurfaced also
Old Nov 22, 2005 | 06:14 PM
its disc....ok appreciate it man...wheres a place i can go to get my rotor resurfaced
Old Nov 22, 2005 | 06:29 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (ebonyrolla7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebonyrolla7 &raquo;</TD></TR><TR><TD CLASS="quote">its disc....ok appreciate it man...wheres a place i can go to get my rotor resurfaced</TD></TR></TABLE>
Any small/large shop will have the ability to resurface your rotors. Even Pep Boys can do it. Take them off yourself and bring them the rotor. Shouldn't cost much at all.
Did you break in your brakes properly? Sometimes when they aren't broken in nicely, they will squeak because they haven't seated to the rotors. If you're unlucky, it won't go away until the next pad change.
Old Nov 22, 2005 | 07:06 PM
SOHCVTECx2's Avatar
Yea do what the following peeps instructed you to do. Change the rotor and he brake pads. Besides that make sure you also buy the QUIET BRAKE spray can so spray behind the pads. That is very crucial, if not it can cause squeaking again and again. Try it out and let me know how it goes.
kevinm1981
Aug 3, 2009 02:24 PM
DIRTYsouthBB6
Jan 11, 2007 12:24 PM
jorge99hx
25
Dec 10, 2005 12:52 PM
Chemicalviper
Dec 16, 2003 06:34 PM
wizzards581
16
Sep 17, 2003 06:16 PM
