weird prob., when you let off the gas... help me out
Old Nov 22, 2005 | 08:41 AM
4LugR's Avatar
Default weird prob., when you let off the gas... help me out
ok, so just recently if im going in 3rd gear or 4th, and am at about 2500-4000 rpm, and i let off the gas, il lugs a little bit.. instead of the usual disengagement, which will be , just a single lug, which is normal when the engine is slowing.. well now it goes " lug lug lug lug" when it slows.. and it kinda jerks quite a few times before starting to slow.. and im not sure what the problem could be.. unbalanced crank somehow?? it just recently started, the clutch has about 8k miles on it, the tranny was rebuilt about 15k miles ago, and the motor has about 35k on it.. any ideas anyone? TIA..
Old Nov 22, 2005 | 11:58 AM
staticrex's Avatar
Default Re: weird prob., when you let off the gas... help me out (AEMPrelude916)
I have noticed this a couple times, I was thinking it had something to do with the throttle cable. I hope its not something internal.
bump, I would like to know also.
Old Nov 22, 2005 | 12:12 PM
4LugR's Avatar
Default Re: weird prob., when you let off the gas... help me out (staticrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex &raquo;</TD></TR><TR><TD CLASS="quote">I have noticed this a couple times, I was thinking it had something to do with the throttle cable. I hope its not something internal.
bump, I would like to know also. </TD></TR></TABLE>
yea, thats what i was thinking, that or the clutch has a small problem releasing...bump
Old Nov 22, 2005 | 11:40 PM
4LugR's Avatar
come on guys.... bump
Old Nov 23, 2005 | 10:41 AM
AnthonyG2003
Guest
Posts: n/a
bump...i too want to know
Old Nov 23, 2005 | 11:57 AM
LudeyKrus's Avatar
I had a problem similar to this with my MR2.
Is your idle a bit rougher? Mileage gone down a bit? Less power?
You may have skipped a tooth w/ your timing belt. Is it throwing a code?
Old Nov 23, 2005 | 01:22 PM
staticrex's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I had a problem similar to this with my MR2.
You may have skipped a tooth w/ your timing belt. Is it throwing a code?</TD></TR></TABLE>
This makes me nervous, since it does idle a bit rougher and is making a metallic noise.
I'm gonna have to pull the valve cover and check it out. Except my car is not throwing any codes.
Old Nov 23, 2005 | 07:42 PM
JTB's Avatar
JTB
Default Re: (staticrex)
need more info define lugs... not real sure what that means never heard that term
Old Nov 24, 2005 | 09:58 AM
4LugR's Avatar
Default Re: (JTB)
thats what i had thought, maybe i had skipped a tooth.. well lugs are like when you let off the gas, and you feel the engine start to slow the car, you get that slight jump forward, before it starts to slow.. thats what i call a lug... it does that several times in a row, not just the usual once, when you let off..
Old Nov 24, 2005 | 01:20 PM
daveedd357's Avatar
check the idle air control valve operation. that is usually the issue with hondas when they jerk off throttle.
Old Nov 24, 2005 | 01:30 PM
4LugR's Avatar
Default Re: weird prob., when you let off the gas... help me out (daveedd357)
ok, ill try that.. but even at like 80 mph?
Old Nov 24, 2005 | 07:05 PM
daveedd357's Avatar
it did it on mine. that was my solution
Old Nov 24, 2005 | 07:11 PM
4LugR's Avatar
cool . thanks man
Old Nov 25, 2005 | 03:01 PM
JTB's Avatar
JTB
so it feels like a down shift in a automatic car?
Old Nov 25, 2005 | 03:36 PM
mrlover's Avatar
my car has same problem, i already cleaned the Idle control valve but still. could be ignition or fuel pump
Old Nov 25, 2005 | 06:33 PM
4LugR's Avatar
Default Re: weird prob., when you let off the gas... help me out (JTB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTB &raquo;</TD></TR><TR><TD CLASS="quote">so it feels like a down shift in a automatic car?</TD></TR></TABLE>
sort of, it just feels like when you let off the gas in a manual car, but it happens a few extra times...lol
Old Nov 27, 2005 | 02:57 AM
f22tsi's Avatar
motor mount
egg_baLLa
Jun 23, 2008 02:53 PM
m2s4drespecial
May 19, 2008 08:33 PM
gtec28
Mar 30, 2007 09:11 AM
importboi22
Sep 25, 2006 04:44 PM
inty2511
May 28, 2003 05:53 AM
