stupid newb ? help plz
i can get a 94 accord that threw a rod for real cheap and i can get 96 h23 longblock? would that swap im not sure if thats even the right motor i just need to know b/c i cant find it b/c the search thing is shut down.
Im pretty sure the the H23 should swap straight in, but you will run in to problems because it is a 96 which means that it is ODBII. I don't know how hard conversions are but you could look for an ODBI motor (95 and earlier) to swap in instead. Someone correct me if im wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Defcon2030 »</TD></TR><TR><TD CLASS="quote">that's skills and/ OR money</TD></TR></TABLE>
no even if you have the skill you still need the money for tools and service manuels. if you have the skills its still not free its just cheaper! and dont be a smartas* on here if you want help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmurphy2k3 »</TD></TR><TR><TD CLASS="quote">Im pretty sure the the H23 should swap straight in, but you will run in to problems because it is a 96 which means that it is ODBII. I don't know how hard conversions are but you could look for an ODBI motor (95 and earlier) to swap in instead. Someone correct me if im wrong. </TD></TR></TABLE>
instead of a 95 motor just get a 95 distributor! its cheaper and he said he had access to a obd 2 motor so just convert it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ujhonda »</TD></TR><TR><TD CLASS="quote">no even if you have the skill you still need the money for beer, because you have to work a$$ off crawling under the car
