D16 Torque specs
Old Nov 21, 2005 | 04:30 PM
Red93AWD's Avatar
Default D16 Torque specs
Before anyone says anything I tried a search and it said the function was not available. With that said I need the torque specs for the rod bolts and the crank bolts for a 93 ex, d16 is the engine code i believe.
Old Nov 21, 2005 | 04:36 PM
Luserkid's Avatar
Default Re: D16 Torque specs (Red93AWD)
By the crank bolts do you mean the main cap bolts?
Honda OEM Rod bolts: 23ft/lbs (if your running another company then contact them for the specs)
Main Caps: Step 1. 18ft/lbs Step 2. 38ft/lbs (for D16z6) 33ft/lbs (for everyone else)
Old Nov 21, 2005 | 04:38 PM
Red93AWD's Avatar
Default Re: D16 Torque specs (Luserkid)
That's what I needed. Thank you sir!
N/A ALL DAY
Engine Management and Tuning
Apr 8, 2012 10:10 AM
eortizr
Aug 23, 2005 10:08 PM
The Jacko
Aug 12, 2005 08:29 AM
SupaFly_Honda
Aug 11, 2004 07:09 PM
