different sized tires
Old Nov 21, 2005 | 04:25 PM
tysn's Avatar
Default different sized tires
i had a tire finally give out on me and i need a temp replacement for a tire till i go home for christmas. i found some 205/60r15 at work and i was wondering if i could put 2 of them on the back and have the 195 up from staying up from while i put the 205s on the back rims?
Old Nov 21, 2005 | 04:50 PM
D21X's Avatar
Default Re: different sized tires (tysn)
that'll probably work
Old Nov 21, 2005 | 04:56 PM
k-mart's Avatar
Default Re: different sized tires (D21X)
yes, you can.
Old Nov 21, 2005 | 06:30 PM
CRXb18Turbo's Avatar
you could put any size as long has the right matches the left side.
Old Nov 22, 2005 | 12:35 PM
tysn's Avatar
Default Re: different sized tires (Group A)
wouldn't that throw off my speedo a little bit?
Old Nov 22, 2005 | 12:48 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group A &raquo;</TD></TR><TR><TD CLASS="quote">u shud put the wider tires up front</TD></TR></TABLE>
who cares, it's a temporay replacement and i dont think anyone going to give a rad **** about geometry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tysn &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't that throw off my speedo a little bit?
over all HEIGHT will trick the speedo but it's like 1-3 percent, i would fart and throw the speedo off
Old Nov 22, 2005 | 03:37 PM
AFAccord's Avatar
Default Re: different sized tires (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">...i would fart and throw the speedo off </TD></TR></TABLE>
WOW... stay the devil away from me!
Old Nov 22, 2005 | 03:51 PM
njflip's Avatar
Old Nov 28, 2005 | 12:37 PM
theways's Avatar
Actually, you're larger tires should go on the rear. Same rule goes for speed rating, even if you drive a FWD or AWD car the highest speed rating / newest tires should go on the rear (for better handling).
-The Ways
pjr710
Aug 11, 2008 08:07 PM
bopbop93030
Jul 3, 2008 02:06 PM
pos_cd5
Apr 27, 2006 08:45 AM
N1NjA TuRtLE
Sep 29, 2003 08:33 AM
b20turboic
Aug 10, 2003 07:01 AM
