broken cam shaft
Old Nov 21, 2005 | 04:10 PM
jsucci's Avatar
Default broken cam shaft
i have a 1992 Honda accord with the factory f22 engine. I was told that the camshaft is broken, i never had the car running or have had the engine apart yet, i got the car in a trade for some work done to another car. Is it easier to change the head to a head with a good cam or change motors, i have a spare motor that i know runs strong. thanks.
Old Nov 21, 2005 | 04:38 PM
P_Adams's Avatar
Default Re: broken cam shaft (jsucci)
It is far easier to change heads, as long as they are the same series.
IE: F22B2 (non-Vtec) to a F22B2
P
Old Nov 21, 2005 | 06:38 PM
hondadude's Avatar
Yep, I'd say get another head. The most common cause of the camshafts breaking is because of lack of oil to the top end; the camshaft journal is probably damaged.
Now bear in mind that the engine may have been run out of oil, so you are rolling the dice that the bottom end is going to be okay.
Old Nov 21, 2005 | 06:45 PM
P_Adams's Avatar
Default Re: broken cam shaft (hondadude)
If it broke directly behind the Cam belt pulley, it's possible the Cam Belt Pulley retaining bolt came loose. Possibly from a previous timing belt job.
P
Old Nov 21, 2005 | 06:47 PM
JTB's Avatar
JTB
Default Re: broken cam shaft (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">If it broke directly behind the Cam belt pulley, it's possible the Cam Belt Pulley retaining bolt came loose. Possibly from a previous timing belt job.
P</TD></TR></TABLE>
i see that lots at work! see where its broken at and let us know and we can give you a idea why it broke
Old Nov 21, 2005 | 07:46 PM
jsucci's Avatar
Default Re: broken cam shaft (JTB)
ok, ill probably have it apart tomorrow afternoon unless we get this snowstorm that they are calling for then ill be out plowing.
Old Nov 22, 2005 | 05:09 PM
JTB's Avatar
JTB
do you work for a plowing co or do you have a plow?
Old Nov 22, 2005 | 07:57 PM
JTB's Avatar
JTB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">More like retreiving cold motorists off Interstate 70. What's the response time to get to someone out there?
P</TD></TR></TABLE>
p what r u talkin about?
Old Nov 25, 2005 | 04:23 PM
jsucci's Avatar
I got the head off today and the other head is ready to go on. Can the head gasket be reused or replaced, it stayed on the head and is in one piece.
Old Nov 25, 2005 | 05:19 PM
P_Adams's Avatar
Absolutely DO NOT reuse the head gasket, the valve cover gaskets or seals. It's false economy, and they will not seal properly.
P
Old Nov 26, 2005 | 06:09 AM
jsucci's Avatar
why do some people say its ok to reuse them since they are not the felt type of gaskets?
Old Nov 26, 2005 | 07:25 AM
P_Adams's Avatar
It has to do with (basically) the relationship between the clamping force applied to the assembly, the 'crush' that's applied to the gasket (so that it may comply with any surface irregularities), the fact that rather than recovering from prior loads; the head gasket retains it's last dimension - so you'd have to apply enormous amounts of torque to ever hope to seal it a second time.
The only reusable head gaskets I've ever heard of are solid copper.
If "some people say its ok to reuse them " wish to chime in on this topic, be my guest.
Old Nov 26, 2005 | 03:33 PM
jsucci's Avatar
got everything back together except for the exhauste. On the distributor theres a 5th wire that on my parts motor was used, on this motor I dont have anywhere to plug it into, is this going to cause a problem?
Old Nov 27, 2005 | 10:40 AM
jsucci's Avatar
everything is back together but it wont fire, engine rotates but will not start. any ideas?
Old Nov 27, 2005 | 12:29 PM
Obsidian's Avatar
probably has something to do with that 5th distributor wire man.
Old Nov 27, 2005 | 01:03 PM
Schmitey's Avatar
Default Re: broken cam shaft (Obsidian)
P you the man (and you knew it was coming ) but I'd have to disagree on the valve cover gasket. Sure you stand a higher risk of leaking but at worst you're going to have a very gradual oil stain. We're not talking oil gushing out or bad compression like with seals or head gasket. If it leaks you tighten it up a little or put some RTV on it, IMO its not worth buying a $20 seal set everytime as long as you're careful when you take it off. Ain't no big deal, if you got a show car or hate wasting a drop of oil be my guest and replace it...its not my money.
I'd replace the motor. Sounds like you got the equipment and the know how if you're asking in the first place. Like he said who know's what the rest of the engine looks like, might be oil starved as well. If you know the other motor is strong and doesn't have any other problems then don't mess with a weak setup that could have issues.
Old Nov 27, 2005 | 03:15 PM
P_Adams's Avatar
Default Re: broken cam shaft (Schmitey)
While I worked as a Flat Rate Technician, I had made a commitment to myself that I would do everything that contributed to doing the job correctly (and only once!), such as not reusing contaminated coolant, gaskets or (in this case) rubber seals.
Yes, I know that in some cases, it can be done. But I've found that over time and milage they get stiff and uncompliant.
Do what you want, but I'll continue to suggest what I feel to be prudent mechanical advise. To advise any other would be less that professional.
Why my attitude? Basically because of the lessons I've learned, and the fact I'm a lazy F&^*%K makes me go the extra step to make sure I do a job only once.
Regards P
Old Nov 27, 2005 | 03:23 PM
P_Adams's Avatar
True, the fifth wire is the hint.
Honda did a switcha-roo here with regards to getting a crank angle signal to the ECM for the EFI system.
Some, like your 1st engine (I believe); had a crank angle sensor mounted just behind the Harmonic Balancer Pulley.
Others, like your 2nd engine (I believe); had a sensor in the distributor which performed the same function
If I'm correct; you've two routes.
Swap over the required stuff from your 1st to thw 2nd engine or
Pound the Threads for prior discussions on this topic.
Old Nov 27, 2005 | 04:10 PM
Schmitey's Avatar
I second the lazy f*ck part. In my case I just rebel and refuse to drive to the store, hence the oil collecting under my oil pan.
Old Nov 27, 2005 | 05:45 PM
jsucci's Avatar
My guess was the 5th wire also. I agree with you P on replacing and not reusing. Usually I do this if the car I'm building is a show car or something I'm going to be driving everyday, but this one is one that I picked up in exchange for doing a motor swap for a guy and I just wanna get it going so I can sell it.
Old Nov 27, 2005 | 08:12 PM
Schmitey's Avatar
oh well that changes everything then if you're selling it
yeah pop the head on, duct tape her together do whatever
Old Nov 28, 2005 | 11:23 AM
jsucci's Avatar
put it together and sell it as is.
Old Jan 2, 2008 | 07:42 PM
roo's Avatar
roo
i have a 92 sohc that over heated then i had head resurfaced then it broke the
cam , the oil light came on
can you help ?
I drilled out the oil orifice like alldata said and then got rebuilt head and the
same thing happened again , help
blackhatch1992
16
Jan 2, 2015 03:47 PM
SSBP-GSR
Dec 20, 2013 08:01 PM
journeyquest
Oct 3, 2011 04:07 PM
92TypeR
Mar 26, 2005 09:17 AM
dogpile5
Dec 10, 2002 07:53 AM
