DIY- ARP stud install- the hard way, but its cheap
Old Nov 21, 2005 | 01:31 PM
DC4_MADMAN's Avatar
Default DIY- ARP stud install- the hard way, but its cheap
Tools-
1/2" ratchet
3/4" deep socket
10-12 washers(Lowes, home depot, etc)
12x1.5 open end lugnut(set of 4 at Pep boys-2.99)
Process-
Hammer out old studs.
Feed ARP studs through backside of hub
Drop washers over stud, and thread on the open ended lugnut
Should look like this-
Here is the part that will require alot of muscle
Use ratchet and socket to pull stud through, using a vice to hold hub would be very helpful, I did not use a vice.
I pulled each stud through as much as possible by hand(holding hub in hand and threading nut)
Once all were as far as possible I used my foot on 2 studs(hub on ground sideways as I step on 2 studs) as I pulled the other 2 all the way through, then flip the hub and do the other 2 studs the same way.
End product should look like this-
I will also have a writup on pulling new wheel bearings into the knuckle and also the hub without using a press in a few weeks.
Hope some find this helpful, if not usually runs about 5.00 per stud to press in.
Old Nov 21, 2005 | 01:39 PM
VRD^sam's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (4door_demon)
Old Nov 21, 2005 | 02:32 PM
Hulk_EJ8's Avatar
Is this safe, and did the studs strip at all while tightening them down?
GREAT writeup and Idea BTW if this really works and is safe. Didn't feel like pulling out the entire thing and taking it to machine shop..
Old Nov 21, 2005 | 02:56 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: DIY- ARP stud install- the hard way, but its cheap (Hulk_EJ8)
yes it is safe however some manufacturers do recommend tack welding the back for peace of mind.
Old Nov 21, 2005 | 03:19 PM
senpai's Avatar
that's how i've always done it
Old Nov 21, 2005 | 03:22 PM
Luserkid's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (senpai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senpai &raquo;</TD></TR><TR><TD CLASS="quote">that's how i've always done it </TD></TR></TABLE>
Same, except i use an Impact gun. But when im to lazy to fill up my tank i use a ratchet.
Old Nov 21, 2005 | 03:30 PM
SoCal EJ1's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">yes it is safe however some manufacturers do recommend tack welding the back for peace of mind. </TD></TR></TABLE>
I heard this same thing.
Looks fine though.
Old Nov 21, 2005 | 03:42 PM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulk_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Is this safe, and did the studs strip at all while tightening them down?
GREAT writeup and Idea BTW if this really works and is safe. Didn't feel like pulling out the entire thing and taking it to machine shop..</TD></TR></TABLE>
I have done 5 of my own cars this way and have never tack welded them and have NEVER had a problem, but thats a decision the induvidual has to make if the man. recomends it.
None of the studs stripped.
I refuse to pay for something i can do with a little muscle.
One thing, DO NOT use this method on Moroso studs, they are too weak and will stretch, learned that the hard way.
Old Nov 21, 2005 | 03:44 PM
sockvtec's Avatar
good info
nowi dont have to pay to replace my studs
Old Nov 21, 2005 | 04:09 PM
JDMCivicEF9's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (sockvtec)
Did the same to mine without tack welding and still running strong. I used ARP studs.
Old Nov 21, 2005 | 04:53 PM
A.E Motoring's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (JDMCivicEF9)
good ****
Old Jan 17, 2006 | 01:00 AM
JDM Vision's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (SPNFEDEJ)
Old Jan 17, 2006 | 01:59 AM
JDM B16 EK's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (JDM Vision)
Old Jan 17, 2006 | 03:25 AM
T.J.'s Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Same, except i use an Impact gun. But when im to lazy to fill up my tank i use a ratchet. </TD></TR></TABLE>
same here, only ever used an impact gun. Never had to tack weld them tho.
Old Jan 22, 2006 | 01:16 PM
wrx'n you's Avatar
do u have to take off the hub or can u just leave it on?
Old Jan 22, 2006 | 02:10 PM
Calvinator's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (WILLFUTHEGREAT)
i left mine on. I just grinded some of the top of the stud so it can slide through.
Old Jan 25, 2006 | 04:12 PM
SinCitiEK4's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (xtremeazian)
Bump oh ****
Old Jan 25, 2006 | 04:44 PM
97spooncivic's Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (SinCitiEK4)
time for me to try
Old Feb 3, 2006 | 01:38 AM
drive4aliving's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">i left mine on. I just grinded some of the top of the stud so it can slide through.</TD></TR></TABLE>
what do you mean? about grinding...
Old Feb 17, 2006 | 12:17 PM
Expletive!'s Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (drive4aliving)
I do the same when installing stud's at home.
Old Feb 21, 2006 | 10:01 AM
rudebwoy's Avatar
I usually lined them up, and hammer them in
Old Feb 21, 2006 | 10:33 AM
ZipTieGUy's Avatar
if you hammer them out, why dont you just hammer them in....?
Old Feb 21, 2006 | 11:29 AM
kaiba's Avatar
Default Re: (ZipTieGuy)
Hammer out then hammer in. the easiest way and cheapest way.
Old Mar 17, 2006 | 01:09 PM
-Gary-'s Avatar
Default Re: DIY- ARP stud install- the hard way, but its cheap (Slaughter)
Yeah, I just grind off a little of the backside and slide it right in.
Screw taking the hub off and doing all that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slaughter &raquo;</TD></TR><TR><TD CLASS="quote">I do the same when installing stud's at home. </TD></TR></TABLE>
Old Mar 17, 2006 | 01:17 PM
IT'S ME DAVID's Avatar
NooB
arent you suppose to tack weld the extended stud to the back of the hub aswell.
bmwe362006
Feb 23, 2009 06:21 PM
timmy0tool
10
Dec 19, 2007 03:25 PM
ekeddie
Suspension & Brakes
10
Oct 14, 2007 12:28 PM
neofreak
Jul 21, 2007 01:47 PM
Civicdrgrcr
Jul 8, 2002 09:45 AM
