Radio Cuts out when i hit boost! WTF?
Just installed a jrsh on my eg. and when i go into boost the radio power goes out and then comes on when not in boost. What the expletive did i do?
oh yea i just installed a jr btm
and afc and somewhere in there i moved the radio to the jdm lower console, though i didnt change any wiring.
Sounds like you have a horrible wiring issue somewhere.. good luck pinpointing it.
This has to be a wiring issue. there is no other way. it must be when your boost gauge starts reading boost that it happens. I would start by looking at the wiring for your boost gauge.
ok, i have a autometer boost gauge which uses a boost source from the engine and acc and ground for the light so i dont think it would be that. though it doesnt seem to be working right either
I think its just a bad unit.
The only thing i can even remotely think it would be is the jr btm. maybe i wired it wrong, and when it sees boost it grounds something out it shouldnt. Ill have to check out the wiring tonight. Any other ideas?
I think its just a bad unit.The only thing i can even remotely think it would be is the jr btm. maybe i wired it wrong, and when it sees boost it grounds something out it shouldnt. Ill have to check out the wiring tonight. Any other ideas?
yellow munson
May 28, 2005 06:51 PM
SRd240sx
Audio / Security / Video
Feb 3, 2005 07:14 PM
