Cannister on back of Block leaking and smoking
Old Nov 21, 2005 | 08:45 AM
88crxhfb16's Avatar
Default Cannister on back of Block leaking and smoking
Smoke is coming from this black box or cannister from the the back of the block. it is also leaking oil there. can it be removed and plugged???
Old Nov 21, 2005 | 08:54 AM
Tyson's Avatar
Default Re: Cannister on back of Block leaking and smoking (88crxhfb16)
thats the oil separator that goes to the PCV valve.
cant say the smoke is normal, its usually supposed to be sealed. buttheres really only a oring that seals that hole.
you could seal it if you wanted with a freeze plug and rely on blowby exiting out through the valve cover hose.
but see if just putting a new oring in there will reseal it.
Old Nov 21, 2005 | 09:28 AM
SETI20's Avatar
replace it...it could be kaputt or full.
Old Nov 21, 2005 | 09:37 AM
Tyson's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">replace it...it could be kaputt or full.</TD></TR></TABLE>
eh? its just a box with a few baffles... any liquid in it will drain back into the engine.
just replace the o ring...
boostedteg4dr
May 12, 2008 01:29 PM
EK_vzla
Mar 18, 2008 05:34 PM
jspecjoe
Jan 19, 2006 11:38 AM
ccivic
Dec 6, 2005 07:29 PM
euclid
Oct 7, 2004 07:16 PM
