Custom 4th gen Accord LED side markers
Old Nov 21, 2005 | 08:29 AM
maroonaccord2.2's Avatar
Default Custom 4th gen Accord LED side markers
My weekend project, custom LED sidemarkers utilizing the OE molding and 5mm water-clear LEDs. The idea was for a functional/additional indicator that is invisible when not lit. I also did not want to punch big holes in my upper fender. Each side consists of 2-4 led arrays wired with a 220 Ohm resistor inline for the voltage drop. I am very happy with the finished product.....
Parts total: $10.00
Old Nov 21, 2005 | 09:15 AM
-RedneckDave-'s Avatar
Working
Default Re: Custom 4th gen Accord LED side markers (maroonaccord2.2)
Looks pretty clean.
Old Nov 21, 2005 | 01:26 PM
Juccord's Avatar
Default Re: Custom 4th gen Accord LED side markers (-RedneckDave-)
looks real nice. Thats what ive been wanting to do.
Old Nov 21, 2005 | 02:43 PM
gianinline's Avatar
I've got to admit.... not only was very creative, but it looks nice too.... did a good job there!!! ...you can do that to mine now if you want... lol
Old Nov 21, 2005 | 07:54 PM
iam7head's Avatar
Default Re: Custom 4th gen Accord LED side markers (gianinline)
You didn't run a parallel on LED setup right?
Old Nov 21, 2005 | 11:56 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: Custom 4th gen Accord LED side markers (iam7head)
1000 points for creativity!
Old Nov 22, 2005 | 12:17 AM
JDM MonopolyMan's Avatar
Good idea! looks good too.
Old Nov 22, 2005 | 05:43 AM
Parallel on LED? Well, each side is 4 amber LEDs wired in series, soldered to that 220 ohm resistor for the voltage drop. Then I used 2 sets of 4 for each side marker. Sealed then up in 100% silicone, and tada!!! Here's a pic of 1 of the circuits.....
Modified by maroonaccord2.2 at 9:43 AM 11/22/2005
Old Nov 22, 2005 | 05:51 AM
fw190bvi's Avatar
nice
do they act as a blinker?
Old Nov 22, 2005 | 06:36 AM
Default Re: Custom 4th gen Accord LED side markers (fw190bvi)
Yes, right now they are tapped off of the front corner lamp....it acts as a running light, and blinks as a signal to. If I wanted them to just blink while signaling, I'd probably move the tap to the front bumper signal. The LEDs have virtually no load charateristics at all, so you can use small gauge wire, and tap off of whatever you like for power.
Old Nov 22, 2005 | 03:51 PM
njflip's Avatar
Old Nov 23, 2005 | 02:48 PM
ujhonda's Avatar
Connecting LEDs in series
If you wish to have several LEDs on at the same time it may be possible to connect them in series. This prolongs battery life by lighting several LEDs with the same current as just one LED.
All the LEDs connected in series pass the same current so it is best if they are all the same type. The power supply must have sufficient voltage to provide about 2V for each LED (4V for blue and white) plus at least another 2V for the resistor. To work out a value for the resistor you must add up all the LED voltages and use this for VL.
Avoid connecting LEDs in parallel!
Connecting several LEDs in parallel with just one resistor shared between them is generally not a good idea.
If the LEDs require slightly different voltages only the lowest voltage LED will light and it may be destroyed by the larger current flowing through it. Although identical LEDs can be successfully connected in parallel with one resistor this rarely offers any useful benefit because resistors are very cheap and the current used is the same as connecting the LEDs individually. If LEDs are in parallel each one should have its own resistor
Reference: http://www.kpsec.freeuk.com/components/led.htm
Old Nov 23, 2005 | 03:35 PM
LiViNgLeGeNd's Avatar
looks good.
Old Nov 23, 2005 | 04:27 PM
JTB's Avatar
JTB
Default Re: (LiViNgLeGeNd)
good job you should pick up some moldings and sell em on ebay
Old Nov 24, 2005 | 07:05 AM
sd93accordex's Avatar
that looks bada$$!!!! i need to do that. cake! i haven't seen anything like that around here. ahhhh..nothing like being first!!
Old Nov 24, 2005 | 09:18 AM
JadedGamerX's Avatar
Default Re: Custom 4th gen Accord LED side markers (sd93accordex)
Great Job! I really like the looks of that. Clean, purposefull.
Old Nov 24, 2005 | 12:27 PM
i20ar's Avatar
you are a genious!!! if you wired those up to your blinkers insted.. you would probably never get cut off again... they look soo bright!
O/T since you know about LED's do you know how to make like a bulb array type thing? ive seeen some at the store but they're really expensive... i thing some nice red led brakelights would make the light much sharper
Old Nov 24, 2005 | 12:57 PM
RoAnSa's Avatar
Default Re: Custom 4th gen Accord LED side markers (Dj14aZnS)
Old Nov 25, 2005 | 09:55 PM
MestizoRacer310's Avatar
Can you take a side angle pic that would include the whole car, or even 5 feet away? I want to see how "invisible" they are unlit.....
k0rupt_ed
May 23, 2009 02:15 PM
gakkuken
May 19, 2005 09:15 AM
accordgangsta
Apr 9, 2003 01:02 AM
spankey167
Jan 6, 2003 06:16 PM
94integra
Jan 1, 2003 11:12 PM
