Best tranny for hybrid CRX?
Old Mar 12, 2002 | 10:46 AM
KKHybridCRX's Avatar
Default Best tranny for hybrid CRX?
My CRX has a '92 B18A with an LS (YS1?) tranny. What do you guys think would be the best tranny for running the 1/4 mile? Y1?
Old Mar 12, 2002 | 10:50 AM
EP3_05's Avatar
Default Re: Best tranny for hybrid CRX? (KKHybridCRX)
JDM S1/J1...has close gears and it has a different final drive than the Y1.
Old Mar 12, 2002 | 11:28 AM
wickedxboi's Avatar
Default Re: Best tranny for hybrid CRX? (91civic)
i'd say the ys1 from the 92-93 gsr
the gear ratios are alot closer than the ys1`s off the ls motors
i believe that tranny is as close as u can get with a type r tranny that is cable
Old Mar 12, 2002 | 11:36 AM
XoSiKCiViCoX's Avatar
UNLESS you want to put some low numbers on your slips, (running high hp like turbo or blower) then you need a little longer gears, so in that case i would suggest sticking with the ls.
Old Mar 12, 2002 | 12:06 PM
marty's Avatar
Default Re: Best tranny for hybrid CRX? (wickedxboi)
YS1 has my vote.. Close gearing ratio. Just like a typeR tranny but cable.
Old Mar 12, 2002 | 12:12 PM
E-lude78's Avatar
Default Re: Best tranny for hybrid CRX? (MugenEF7)
I have the YS1 tranny. The only prob I have is that the main bearings may be shot. It makes a loud whining noise while i drive.
Old Mar 12, 2002 | 12:20 PM
marty's Avatar
Default Re: Best tranny for hybrid CRX? (Mista B-one-seven)
you also have a Bee One Seven that comes with that tranny
Old Mar 12, 2002 | 02:03 PM
Damn, I should have put it up to a vote. I think I got one post for each tranny. Anyone know of a good place to get any of the ones mentioned? Salvage yard or do some JDM motor suppliers sell trannys too? In CA of course.
Thanks for the responses.
Old Mar 12, 2002 | 05:21 PM
Bnjmn's Avatar
92-93 GSR trannies are $$$. $750+
Ben
Old Mar 12, 2002 | 05:37 PM
E-AT_me's Avatar
Default Re: Best tranny for hybrid CRX? (Bnjmn)
i have a quaife for a 92-93 GSR tranny... for sale... but not the tranny itself. i have a J1. i need to do the swap so i have no input for you there.
Old Mar 12, 2002 | 06:27 PM
E-lude78's Avatar
Default Re: Best tranny for hybrid CRX? (Rexman)
how much you askin for the Quaife?
Old Mar 12, 2002 | 07:23 PM
StorminMatt's Avatar
Use B16A/B17A transmissions on a B18A/B18B/B20 ONLY if you don't plan to use the car alot on the freeway. Because the extended high revs WILL shorten the life of the motor.
Old Mar 12, 2002 | 07:31 PM
E-lude78's Avatar
Default Re: Best tranny for hybrid CRX? (StorminMatt)
I think highway driving is more beneficial for the engine than stop-and-go city driving.
Old Mar 12, 2002 | 11:49 PM
Not at 4800-5000rpm it isn't.
Old Mar 13, 2002 | 02:26 AM
samiam's Avatar
Isn't there a difference between the jdm ys1 and usdm ys1? I got the impression that the jdm ys1 had gearing similar to the type r, only with out the 4:78 final drive.
black0hatch
Aug 31, 2008 04:53 PM
Skittles
Sep 12, 2005 10:23 PM
c1v1c89h4tch
16
Mar 7, 2005 02:36 PM
paulzy
Nov 14, 2002 09:42 AM
