Problem with my clutch!
Old Nov 21, 2005 | 05:32 AM
hatchsi0485's Avatar
Default Problem with my clutch!
Hey guys I have had this problem with my Clutch latly and now I can't get my car in gear. I noticed that the clutch wasn't engaging until i pushed down farther and farther on it. So I had to press the clutch the whole way down to be able to change gears, when i used to bairly have to push on it at all. Well this morning I went to go to class and I'm parked in a spot backwards so my transmition sat in reverse and when I turned the car on all of a sudden it starts goin.. with out me on the gas or anything and the clutch gets stuck in the down position, and now im left without being able to shift into any gears. I don't know if there is some adjustment I need to make on the clutch or what, but it doesnt seem to be engaging at all now and has not been engaging until the pedal is pressed down to the floor board the last few days.. I haven't driven it much since i noticed it happening. Any help would be appreciated
Old Nov 21, 2005 | 06:13 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Problem with my clutch! (hatchsi0485)
check your clutch master cylinder for fluid.. i bet it's bone dry. sounds like you have a leak in your clutch system some where and your clutch fluid has all leaked out. this means there is no pressure in your system, and the clutch pedal is not disengaging your clutch. it also means that you have prolly fucked up your synchros really bad by driving around like that.
5.4ever
Oct 5, 2009 05:38 AM
98R-1144
May 12, 2007 09:39 AM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
y0whuddupb
Sep 6, 2005 01:11 AM
jdmteg95
Dec 17, 2002 03:52 AM
