Under Dash fuse box options
Old Nov 21, 2005 | 01:05 AM
kcjohnnyboy's Avatar
Default Under Dash fuse box options
i was searching and came up with just a pic but couldnt figure out what each of the "options" stand for...one has to be constant, ignition, accessory, and etc. can someone help me out and tell me what is what...what is 1,2,3,4, and 5 correspond to... i was needing to know this to wire up my power windows to..thanks
Old Nov 21, 2005 | 11:34 AM
Default Re: Under Dash fuse box options (kcjohnnyboy)
bump for a lil help out there
Old Nov 21, 2005 | 12:00 PM
Tyson's Avatar
i forget what the 1-2 pair of options are for, but the 3-4-5 options are constant +12V, ground, ignition +12V, respectively. useful for tapping into power for any accessory, and if you want it only turned on when the car is on or always powered. i might have 3 and 5 mixed up, just test it.
Old Nov 21, 2005 | 12:29 PM
XJamesX's Avatar
Default Re: Under Dash fuse box options (Tyson)
I belive 1&2 are both constant. I could be confused aswell but it is easy to test.
-James-
Old Nov 21, 2005 | 01:32 PM
thanks...how would you test the other two pair of options...with a test light? i never used a test light before...haha
Old Nov 27, 2005 | 12:47 AM
i searched a lil bit and found out the #3 is the ignition...but im unsure for the other four options
Rooftop voter
Mar 15, 2011 01:05 PM
goheel
Dec 7, 2007 01:56 PM
mchuang
Sep 2, 2005 08:53 PM
JDMlyfestyle
Dec 18, 2003 03:03 PM
enrique
15
Jul 15, 2003 08:29 AM
