Gear Grinding on EP3 Si
Old Nov 20, 2005 | 10:35 PM
army2005's Avatar
Default Gear Grinding on EP3 Si
I recently purchased a used Civic Si w/ 32,000 miles... I noticed that 3rd gear grinds occasionally/frequently especially when shifting at higher rpms and speeds. I heard somewhere that this is common for this model. Anyone have similar experiences??
Old Nov 21, 2005 | 04:06 AM
sk8flex's Avatar
Default Re: Gear Grinding on EP3 Si (army2005)
Maybe changing your gear box oil will help, I´d give it a try.
Old Nov 21, 2005 | 04:51 AM
Mechanic's Avatar
Is this common? Yes, very common, depending on how you drive the car. It's not unique to EP3s. The RSX and S2000 boards also describe this in detail. If you haven't been to http://www.ephatch.com, I'd start reading there.
Old Nov 21, 2005 | 11:22 AM
KOREAN's Avatar
Default Re: Gear Grinding on EP3 Si (Mechanic)
i had the 2nd gear grinding problem on my dc5. sadly, the acura dealership said they couldn't do anything about it. so i just had to change my 2nd gear shifting...
Old Nov 21, 2005 | 03:18 PM
mrDFWmechanic's Avatar
wow i guess it is common cause i've had 2 friends now in a year that had the same problems both got it fixed from warranty. they were both black ep3's thou is yours black haha jk
Old Nov 21, 2005 | 05:43 PM
army2005's Avatar
I should clarify that it's not like a true grind (like when you mis-shift or don't have the clutch fully depressed), but more of the "clunk" noise when shifting into 3rd. Doesn't happen all the time, but a lot of times even with the clutch fully depressed. Don't know if the synchros are bad, or if trans oil related (only 32,000 miles, bought USED) or if it's nothing that's concerning. (BTW, do these trans use triple cone synchros)?
Old Nov 22, 2005 | 01:24 PM
limey156's Avatar
If you don't actually hear a gridning noise similar to you sticking a fork in a fan thats spinning then you don't have anything wrong with your car. You being able to feel the car go into gear is called positive assurance that you completed the shift.
Old Nov 23, 2005 | 09:55 PM
SiRocket02's Avatar
my 02 started having the problem around 35,000 miles. It pissed me off man. but I complained to Honda twice and neither time could they confirm the problem. at 42,000 i went in for an oil change and had a tech ride with me and got the car to grind and make another sound which turned out to be clutch. The car hadnt even been to the track in a year and is babied now because if this damn gas price ****. But Honda covered my third gear syncro and went through the tranny and covered it under warrany. annnddd while it was all apart i went ahead and put a new exedy race clutch and act prolyte flywheel on it. just talk to your dealer. the syncro problem is in a honda service bulletin and should be covered under the drivetrain warranty.
Old Nov 24, 2005 | 06:18 PM
Hondaguy_88's Avatar
Default Re: Gear Grinding on EP3 Si (SiRocket02)
my buddies black 04 civic si dose the same thing while shifting at higher rpm's goin into 3rd cause he was askin me what it was it didn't really sound like a loud grind just kinda slight noise....
Old Nov 25, 2005 | 06:01 PM
thid92's Avatar
can I haz?
Default Re: Gear Grinding on EP3 Si (korean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korean &raquo;</TD></TR><TR><TD CLASS="quote">i had the 2nd gear grinding problem on my dc5. sadly, the acura dealership said they couldn't do anything about it. so i just had to change my 2nd gear shifting... </TD></TR></TABLE> i have the same problem and i dont even have 1k miles yet on my new baby.
Old Nov 29, 2005 | 06:46 AM
Honda.F1's Avatar
Default Re: Gear Grinding on EP3 Si (thid92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 &raquo;</TD></TR><TR><TD CLASS="quote"> i have the same problem and i dont even have 1k miles yet on my new baby. </TD></TR></TABLE>
that sucks !
I would go to the dealer again and again until they fix it.
Call Acura and complain and see what they say. There is a TSB out on it so the dealer must fix it for free. Print it out and take it to the dealer.
TSB ---&gt; http://rsx.clubrsx.com/bulleti...n.pdf
http://www.petitiononline.com/....html
http://forums.clubrsx.com/show...27026
Old Nov 29, 2005 | 06:59 AM
thid92's Avatar
can I haz?
Default Re: Gear Grinding on EP3 Si (Honda.F1)
thanks for the links.
Its just like they describe it on those forums, it is a little notchy from 1st to 2nd when its cold but goes away after warmed up.
Old Nov 29, 2005 | 07:25 AM
Honda.F1's Avatar
you're welcome
I hope it helps.
you may want to take it to a different Acura dealer if you keep getting the run around from one.
Old Nov 29, 2005 | 06:00 PM
thid92's Avatar
can I haz?
thanks again.
Old Nov 30, 2005 | 12:35 PM
mysrt4isfast's Avatar
Default Re: (thid92)
i had this problem on mine too but it was covered by the warranty so no big deal at all
Old Nov 30, 2005 | 12:56 PM
ekferio's Avatar
damn i thought this is a problem with rsx only
Old Dec 1, 2005 | 05:40 PM
02ep3's Avatar
Default Re: (ekferio)
my ep has about 60k miles on it...now i bought it used but i have never experienced any type of noises shifting. but you did say it was gone over time so that could possibly be it....when i got it, it was already worked out
jdmshawn95
Honda Civic (2006 - 2015)
26
Nov 2, 2010 10:27 AM
kriptonian7
10
Aug 7, 2010 06:59 PM
atmosphere
10
Sep 20, 2006 06:26 PM
MD06LBP
Jul 8, 2006 11:59 AM
ROCcityRSX_S
Dec 10, 2004 01:35 PM
