Spoon Brake Rotors?
Old Mar 12, 2002 | 09:52 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Spoon Brake Rotors?
Do any of you guys have the Spoon slotted rotors on your R? Just wanted some opinions of them.
Old Mar 12, 2002 | 01:25 PM
owen_the_soyboy's Avatar
Default Re: Spoon Brake Rotors? (ActiveAero)
Spoon rotors = too much $$$$$$$$$$ for the performance they provide
get OEM ITR rotors and send them to get cryo-treated so they last you three time as long.
Old Mar 12, 2002 | 01:26 PM
B2FiNiTY's Avatar
I might get them when I get my calipers just because their spoooooooon.
Old Mar 12, 2002 | 01:56 PM
BlazinITR's Avatar
New User
Default Re: Spoon Brake Rotors? (B2FiNiTY)
Mike has them on his ITR!
Old Mar 12, 2002 | 01:57 PM
yellow blur's Avatar
Nice reasoning...
Old Mar 12, 2002 | 02:00 PM
B2FiNiTY's Avatar
Default Re: Spoon Brake Rotors? (yellow blur)
Hey it's better than Mugen.
Old Mar 12, 2002 | 02:05 PM
Reid's Avatar
Global Moderator
Actually aren't the Mugen rotors larger than stock? Hence they'd be better than the stock sized Spoons.
Old Mar 12, 2002 | 02:45 PM
Flux's Avatar
Default Re: Spoon Brake Rotors? (Reid)
I've thought about the Spoon rotors - but I've been looking at the Endless rotors recently as well...
Old Mar 12, 2002 | 02:47 PM
BlazinITR's Avatar
New User
Default Re: Spoon Brake Rotors? (Flux)
Aren't the Spoon Slotted as well!
Old Mar 12, 2002 | 03:32 PM
ITR-585's Avatar
Default Re: Spoon Brake Rotors? (Blazin ITR)
I have the SPOON slotted rotors and like them much better over stock. As long as you use any other pad other than stock you should feel a big difference. I'm using Endless pads all around and the car seems to stop a lot better than stock. And they really aren't that expensive for a slotted rotor........... IMO
Old Mar 12, 2002 | 03:33 PM
Warren's Avatar
Wrong-Way Wang
Anyone that actually buys either of these rotors seriously needs their head checked.
Warren
Old Mar 12, 2002 | 03:52 PM
AllMotorITR's Avatar
New User
Default Re: Spoon Brake Rotors? (Warren)
Why do you say that?
Old Mar 12, 2002 | 03:54 PM
Type Goch's Avatar
New User
Default Re: Spoon Brake Rotors? (1 FAST R)
because most likely the only reason why people will buy it is because of the name, even though its way overpriced. *shrug*
Old Mar 12, 2002 | 04:24 PM
Stock-DC2's Avatar
New User
I wish I have that much money to waste.
Old Mar 12, 2002 | 05:57 PM
BlazinITR's Avatar
New User
Default Re: Spoon Brake Rotors? (Type Goch)
David has them one sell!
Old Mar 12, 2002 | 05:58 PM
B2FiNiTY's Avatar
Huh?
Old Mar 12, 2002 | 06:29 PM
AJ PwR's Avatar
Spoon's rotor are made by Honda with a higher grade material. They also have some sort of coating on the rotor to avoid rust. I mean it's a nice piece and I think they are not overpriced parts.
Old Mar 12, 2002 | 06:32 PM
B2FiNiTY's Avatar
Default Re: Spoon Brake Rotors? (AJ PwR)
Are they larger than stock? Or just specially treated stock rotors?
Old Mar 12, 2002 | 06:39 PM
Warren's Avatar
Wrong-Way Wang
I'll bet a case of beer that they don't stop one inch shorter than stock, or even Autozone legend rotors. Slap on some race pads and they'll glow orange just like any other rotor.
Warren
Old Mar 12, 2002 | 06:42 PM
Cold Chunker's Avatar
If you need rotors, go w/stock or Brembo OE's. The slots do nothing for you.
1 - Less brake rotor mass, so less heat can be absorbed
2 - if rotors warp, they *basically* can't be turned
3 - slots fill up w/brake pad material
If you like to buy rotors, then go get em.
Check what the race teams run. That'll give you a big clue.
Old Mar 12, 2002 | 06:50 PM
KekeK-18's Avatar
can't agree with you more.....total rip off!!
Old Mar 14, 2002 | 07:42 PM
jdmtyper680's Avatar
Default Re: Spoon Brake Rotors? (KekeK-18)
the spoon rotors where only 140 each - they feel better than stock/ but not by much with stock pads/ with aftrmrkt pads, the rotors feel alot better. Plus slotted is nice So expensive NOPE! ALso these are not bigger rotors if they were your stock caliper would not be able to compinsate without a full replacement caliper -which i intend to do anyways.
Old Mar 14, 2002 | 07:47 PM
Type Goch's Avatar
New User
Default Re: Spoon Brake Rotors? (jdmtyper)
Must be nice having cash to burn?
Old Mar 14, 2002 | 07:52 PM
ITRbroham's Avatar
shit post warrior
I dun think 140/each isn't bad for the Sp00m rotors!
[Modified by ITRbroham, 9:14 PM 3/14/2002]
Old Mar 14, 2002 | 07:55 PM
how can an upgrade be a waste. or " money to burn". I wanted a cost effective upgrade. Those rotors I researched seem to be the best decision. I work for my money - not you. So if you want to give some of yours then I'd be more than happy to fix up my car the way you think it should be.
