HELP! WHICH CAMS???! and....
Old Nov 20, 2005 | 07:29 PM
93EG6SI's Avatar
Default HELP! WHICH CAMS???! and....
I have a B16B CTR swap in my eg hatch, im going to use omni power springs and Ti retainers. Which cams am I going to want to use to get a GOOD gain? I plan on shifting at 9K, does anyone know what the highest I could "safely" rev. this stock ctr bottom end upto? im assuming around 9K.
I'm unsure on piston/valve clearance. Thank you.
Old Nov 20, 2005 | 08:01 PM
Adi Radoncic's Avatar
On Fire!
Default Re: HELP! WHICH CAMS???! and.... (93EG6SI)
Jun III, or Rocket M22's will both work great for ya... I wouldn't rev that block more than 9k if you want it to last for a while...
Old Nov 20, 2005 | 08:07 PM
93EG6SI's Avatar
Default Re: HELP! WHICH CAMS???! and.... (Adi Radoncic)
thanks i appreciate the info, is there anything with more lift that i could safely use? is 12.5 or 12.7mm advisable?
Old Nov 20, 2005 | 09:09 PM
93EG6SI's Avatar
BUMP!!!
Old Nov 20, 2005 | 09:30 PM
On Fire!
More lift doesn't necessarely mean more power for ya, from the sound of it the motor is completely stock with some supporting mods. When your choosing cams you need to think about the whole motor as a packige and so with your compression those cams are about the max I would run on that setup.
Old Nov 20, 2005 | 09:52 PM
93EG6SI's Avatar
thanx again. im gonna talk to the local tuner tomorrow and see what he thinks.
1995Civiccx
12
Jun 10, 2007 06:41 PM
Vtakkk
11
Mar 27, 2006 09:52 AM
asocallocal
27
Jun 13, 2005 12:31 PM
riceball777
Dec 6, 2003 10:48 PM
kid_dynamite64
16
Jul 8, 2002 12:41 AM
