Teg sway bar on 91Si?
You can use one from a DA (sedans have even bigger swaybars fyi) and I'm pretty sure it works with your stock LCA's.
PLEASE someone correct me if I'm wrong.
*edit* that's ^ REAR swaybar
Front sways from DA should work also!
only the DA swaybars will fit like stock.
and only the FRONT swaybar is any bigger than your 91 Si.
DA front swaybar is 23mm and hollow. compared to the stock 18mm solid bar.
the rear swaybar is actually smaller than Si. not by much. but theres nothing gained by switching.
the DC rear MAY fit, but it would be connected to the subframe if it did. and the crx subframe is not reinforced like the ITR, and youll likely have issues like those who put ITR bars on their civics.
the front DC bar will absolutely not fit.
importboi22
12
Mar 8, 2004 04:14 AM
