ls swap question
i have a 90 hatch that i have allready converted to mpfi. now i am doing the b18a swap. im wondering if im going to need to use the ls wire harness or will my modified dx one work?? thanks
HOOKER
HOOKER
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jack_attack »</TD></TR><TR><TD CLASS="quote">if you've already converted your car for mpfi then its just a matter of swapping </TD></TR></TABLE>
Most of the wiring is done. You have to change some wires around because you are going from sohc to dohc. I'm not sure which sensor you need to change the wiring for. I think it might be the tdc sensor or the crank position sensor, not sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE »</TD></TR><TR><TD CLASS="quote">and what about the knock sensor? </TD></TR></TABLE>
b18a/b doesn't have a knock sensor.
chris
chris
happyabortion
Sep 17, 2006 06:43 PM
ef_Racer
May 7, 2004 11:53 AM
