Rear Brakes Upgrade !!!
Old Mar 12, 2002 | 07:21 AM
happyclown_69's Avatar
Default Rear Brakes Upgrade !!!
Hi !
On my Civic EX 98 ...
I heard that CRX SI 91 rear brake system could be a bolt-on upgrade ...
Is it true ??
Old Mar 12, 2002 | 07:22 AM
Spade's Avatar
Default Re: Rear Brakes Upgrade !!! (happyclown_69)
Not sure about the CRX but, Del Sol will work.
Old Mar 12, 2002 | 07:39 AM
Feuerraeder's Avatar
Assuming it's a coupe, you want 99-00 Si LCA's, rotors, master cylinder, proportioning valve etc. Dunno about 4 doors
Old Mar 12, 2002 | 08:14 AM
cjames235's Avatar
Default Re: Rear Brakes Upgrade !!! (beatdown88hf)
i believe that they will because in scc they put the crx si rear brakes on their project eg hatch. gsr brakes fit on the 5th gen hatch and the 6th gen coupes. so i think that the crx ones would fit since they fit on the 5th gen hatch. catch what im tryin to say?
Old Mar 12, 2002 | 08:42 AM
Spade's Avatar
Default Re: Rear Brakes Upgrade !!! (civicdisobedience)
4 doors are easy, find a four door with ABS and swap. 4 door ex's with abs had four wheel disk.
Old Mar 12, 2002 | 09:39 AM
Kalokohan's Avatar
New User
Default Re: Rear Brakes Upgrade !!! (cjames235)
I read that article too. From that theory, it should work.
Old Mar 13, 2002 | 05:15 AM
cjames235's Avatar
Default Re: Rear Brakes Upgrade !!! (Guardson3r3)
and also people take 1gen integra brakes and put them on their crx's, so that should mean that they will fit on civics too.? you could probably pick up some of those for real cheap.
Old Mar 13, 2002 | 07:50 AM
Bs's Avatar
Bs
crx's don't have rear brakes.
Old Mar 13, 2002 | 09:26 AM
Civic242's Avatar
Default Re: Rear Brakes Upgrade !!! (B_s)
All 5th and 6th Gen Civics/Del Sol/Si/SiR and 3rd Gen Integra/Type R rear disc brakes will swap as a bolt on. You may need different parking brake cables but you do not need to swap the booster, master cylinder or proportioning valve to do this upgrade.
==> http://home.mpinet.net/t-hero/DiscBrakes!!.htm
Old Mar 13, 2002 | 09:28 AM
Reid's Avatar
Global Moderator
All Hondas have rear brakes, but not all have rear disc brakes (which is what I think you may have been trying to say).
Old Mar 13, 2002 | 09:52 AM
memphiss13's Avatar
uh actually 90-91 crx si's had all wheel disc brakes, don't start talking like people don't know anything when u don't even know yourself.
[Modified by rookie2nr, 12:57 PM 3/13/2002]
Project T
Oct 10, 2008 08:12 PM
h22civ
Dec 7, 2006 03:29 PM
Gumbey75
Jan 15, 2005 12:50 AM
Phat_GSR
Sep 17, 2002 06:11 AM
