ITR front anti-sway bar fit on 00' DX?
Old Nov 20, 2005 | 09:52 AM
SkRiBLaH's Avatar
Default ITR front anti-sway bar fit on 00' DX?
probibally shouldent be asknig here, i know ill get a shitloads of mis-information. but here we go.
are their provisions in teh front of a 00 DX hatch for the ITR front sway bar? lower A arms etc. etc.
Old Nov 20, 2005 | 10:11 AM
kyden's Avatar
Default Re: ITR front anti-sway bar fit on 00' DX? (SkRiBLaH)
not sure on itr, but si you can use. 26mm, but you need si front lca's.
Old Nov 20, 2005 | 11:29 AM
straywise's Avatar
Is best to use the integra subframe with the lower control arms, The DX subrame may work but you would need to figure out a way to attach the sway bar mounts to the subframe and control arms. I put a complete 95 integra subrame in my 96 EK DX, bolted right up.
Old Nov 20, 2005 | 10:03 PM
SkRiBLaH's Avatar
Default Re: ITR front anti-sway bar fit on 00' DX? (straywise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by straywise &raquo;</TD></TR><TR><TD CLASS="quote">Is best to use the integra subframe with the lower control arms, The DX subrame may work but you would need to figure out a way to attach the sway bar mounts to the subframe and control arms. I put a complete 95 integra subrame in my 96 EK DX, bolted right up.</TD></TR></TABLE>
wow. did you have to replace the stearing rack also?
Old Nov 20, 2005 | 11:03 PM
eg6sir-s's Avatar
its easier if you just get an 99-00si front sway or jdm ek9.
Old Nov 22, 2005 | 03:21 PM
straywise's Avatar
I used the steering rack from the integra as well.
Old Nov 22, 2005 | 03:25 PM
straywise's Avatar
The Si sway bar will only work with the Si lower control arms though. Do not know about the type R it may work with integra or civic EX lower control arms.
jah808_eg
Jun 13, 2008 03:00 PM
timmy0tool
13
Dec 18, 2006 10:06 PM
AFTERZERO
Aug 16, 2004 08:16 AM
2khb
Feb 14, 2003 10:07 AM
lp3kr
Sep 11, 2001 05:35 PM
