ITR LOWER CONTROL ARMS INTO CIVIC EK
I was wondering if itr front lower control arms will fit my 99 civic ek? I recently got a nice swaybar for a type r, but my civic dx doesnt have the mounting holes for the swaybar to be mounted. Will the itr front lower control arms bolt right in? any info will be helpful..
Location: just when you thought you were different, WA, NWforLIFE
Re: ITR LOWER CONTROL ARMS INTO CIVIC EK (crisparra)
itr's are too short....so are dc's and eg's...ek's are long...nuff said peace
you can run the bar still...EK's LCAs DO HAVE swaybar mounting holes (even if they don't come with a rear sway from the factory), I know this because I have a 2000 dx hatch myself...you will need to run Si endlinks
I would look into a ASR or Beaks reinforcement kit if the diameter is large (22mm+)
Re: ITR LOWER CONTROL ARMS INTO CIVIC EK (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">you can run the bar still...EK's LCAs DO HAVE swaybar mounting holes (even if they don't come with a rear sway from the factory), I know this because I have a 2000 dx hatch myself...you will need to run Si endlinks
I would look into a ASR or Beaks reinforcement kit if the diameter is large (22mm+)</TD></TR></TABLE>
this applies but he is talikng about fronts.
front DC LCAs can only be used if you use DC front crossmember/steering rack.
otherwise don't bother slapping just DC/EG type sway bar , as there is not enough clearance.
your alternative for the front is: 99-00 Si front LCAs and bar or 96-00 EX front LCas and bar. rear can be sourced off the 99-00 Si for best results.
well i also have a question about this topic. I just recently got a set of gsr breaks, arms, knuckes yada yada everything. I want to run srr rear lowers, should i buy them for my car or should i buy them for a gsr?
Re: ITR LOWER CONTROL ARMS INTO CIVIC EK (eg6ajk)
yes - sorry for the confusion...i thought he was talking about a REAR sway me for not picking that up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">
your alternative for the front is: 99-00 Si front LCAs and bar or 96-00 EX front LCas and bar. rear can be sourced off the 99-00 Si for best results.</TD></TR></TABLE>
what he said ^ a good place to source a si front sway bar swap (bar, endlinks, lca's, & forks) is http://www.importautosalvage.com
