Replace gasket with new valve cover?
Old Nov 20, 2005 | 09:03 AM
TheLiberator's Avatar
Default Replace gasket with new valve cover?
I just bought a red valve cover to replace my old, paint chipped black one on my 1998 GS-R. Do i need to buy a new gasket or can i just reuse the old one? I assume it would be better to replace. Is there anything specific i should know when installing the new valve cover? It seems pretty straight forward. Thanks.
Old Nov 20, 2005 | 09:07 AM
mmuller's Avatar
Mad Scientist
Default Re: Replace gasket with new valve cover? (TheLiberator)
yep, its just as easy as it looks.
I would only change it if the rubber is getting hard. If anything the spark plug groomets are the 1st ones to go
Old Nov 20, 2005 | 10:31 AM
Padawan's Avatar
Darth ModerVader
One thing I would caution against is over-tightening when installing the new cover. While I've never had it happen personally, many people seem to have issues with shearing the bolts.
Old Nov 20, 2005 | 12:52 PM
projectTeG's Avatar
Default Re: Replace gasket with new valve cover? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">One thing I would caution against is over-tightening when installing the new cover. While I've never had it happen personally, many people seem to have issues with shearing the bolts. </TD></TR></TABLE>
if yours hasnt been replaced recently then id say replace it, wehn i put a new gasket in i usually replace it after ive taken the cover off a few times.
Old Nov 20, 2005 | 01:58 PM
Jatt87's Avatar
Yea I would replace it whenever u take the valve cover off
Old Nov 20, 2005 | 02:17 PM
aspec101's Avatar
Default Re: Replace gasket with new valve cover? (Jatt87)
yep replace it and use hondabond light coating and it will seal perfectly.
Old Nov 20, 2005 | 02:27 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jatt87 &raquo;</TD></TR><TR><TD CLASS="quote">Yea I would replace it whenever u take the valve cover off</TD></TR></TABLE>
i wouldnt go that far about it. my last one lasted for about 15 removals before leaking.
onah
14
May 14, 2007 11:45 PM
Dc2 Powered
Aug 4, 2004 11:15 PM
B18C-VTI_R
Jul 20, 2004 04:03 AM
stew18564
18
May 8, 2004 09:23 PM
HONDA-2NR
18
Mar 7, 2004 07:13 PM
