better engine f20b or h22
Old Nov 20, 2005 | 09:02 AM
belz513's Avatar
Default better engine f20b or h22
aight heres the deal im going to be putting a new engine in my 97 accord coupe. Im not sure whether or not i want to get the h22 or the f20. They both put out the same horsepower but the h22 has more torque. I plan on putting many aftermarket parts on the car, internals, turbo, intake exhaust etc. which one would be the better motor to use.
Old Nov 20, 2005 | 09:07 AM
eahill's Avatar
Default Re: better engine f20b or h22 (belz513)
id go h22 there are more parts around for it so if anything happens to the motor you are not spending so much money on parts
Old Nov 29, 2005 | 10:52 PM
Spectrum24x's Avatar
Default Re: better engine f20b or h22 (eahill)
Other then the parts problem, wouldnt the f20b be a better motor in the long run, considering it can rev higher, you'd have more potential
Old Nov 30, 2005 | 03:43 AM
The_Todd's Avatar
Farts in the shower
h22 is cheaper but they are basically the same motor.
Old Nov 30, 2005 | 05:22 AM
i_kick_turtles's Avatar
If you plan on going turbo you'll need to resleeve the h22.
Old Nov 30, 2005 | 05:26 AM
shavedH22AKCL's Avatar
Default Re: better engine f20b or h22 (I R Tylor)
H 2 2 Please
Old Nov 30, 2005 | 07:38 AM
lamsv's Avatar
Default Re: better engine f20b or h22 (shavedH22AKCL)
These motors are different animals. The f20b was created so that Honda could compete in touring class, which had a 2.0L maximum displacement. Basically, the f20b is a destroked h22, which gave it more of a square dimension (there are more differences from the h22 than just stroke, but this is the big reason that makes the motor so different from the h22). The shorter the stroke, the more it can rev. You get the same power of the larger h22, but at a loss of low-end torque. In the heavier Accord chassis, I would probably shy away from the f20b. Unless you were going to go forced induction. Boy, a boosted f20b. All those revs with a turbo could equal some big power. Ultimately, niether engine is really "better", they are just different. But, unless you want to stand out, go h22.
Old Nov 30, 2005 | 08:35 AM
JDM MonopolyMan's Avatar
Default Re: better engine f20b or h22 (lamsv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lamsv &raquo;</TD></TR><TR><TD CLASS="quote">These motors are different animals. The f20b was created so that Honda could compete in touring class, which had a 2.0L maximum displacement. Basically, the f20b is a destroked h22, which gave it more of a square dimension (there are more differences from the h22 than just stroke, but this is the big reason that makes the motor so different from the h22). The shorter the stroke, the more it can rev. You get the same power of the larger h22, but at a loss of low-end torque. In the heavier Accord chassis, I would probably shy away from the f20b. Unless you were going to go forced induction. Boy, a boosted f20b. All those revs with a turbo could equal some big power. Ultimately, niether engine is really "better", they are just different. But, unless you want to stand out, go h22.</TD></TR></TABLE>Totally agree, so it all depends on how much he wants to build it, what his goals are for power. If he wants a better power band at higher rpms with boost, then f20b would be the better choice, if he wants a good daily driver engine, the h22 would better suit him. If it were me, sence I'm all for auto cross, I'd go for the f20b with boost.
Old Nov 30, 2005 | 08:49 AM
lamsv's Avatar
i magine the power with a disco potatoe on an f20b. with those revs, you could hold gears between corners at the auto-x....always being on boost. makes me happy thinking about it....
oem_certified_accord
Aug 3, 2007 09:13 AM
thing
Feb 9, 2006 06:04 PM
civic_std
10
Dec 21, 2005 09:57 AM
tranceguy
Oct 5, 2002 10:44 AM
