more trouble w/b16a in the crx
Old Nov 20, 2005 | 07:48 AM
WERD up's Avatar
Default more trouble w/b16a in the crx
im not sure but i think i'm having distributor problems. everytime i fire up the car the idle sits at around .5 rpm sometimes even lower. when i hit the gas the car dies out. no cel or ecu error. diagnosis?
Old Nov 20, 2005 | 07:49 AM
Boosted Chemist's Avatar
Default Re: more trouble w/b16a in the crx (werd_up)
how is your timing, is the firing order correct?
Old Nov 20, 2005 | 07:50 AM
WERD up's Avatar
Default Re: more trouble w/b16a in the crx (Boosted Chemist)
i tried to adjust the timing myself, and when i did the rpm finally went up over 1500 rpm but everytime i give it some gas it always dies out.
Old Nov 20, 2005 | 08:25 AM
WERD up's Avatar
anybody? i need to get this shitbox up and running.
Old Nov 20, 2005 | 10:54 AM
phan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">..is the firing order correct?</TD></TR></TABLE>
Old Nov 20, 2005 | 12:43 PM
91whiteZCrex's Avatar
Default Re: more trouble w/b16a in the crx (phan)
if you let it warm up does it still do the same thing or not.
if it doesnt do it when it warms up change your intake air temp sensor. mine was bad and unless you let it warm up all the way it would die if you touched the gas a tiny bit
Old Nov 20, 2005 | 01:15 PM
WERD up's Avatar
Default Re: more trouble w/b16a in the crx (91whiteZCrex)
firing order is correct, but now it doesnt even start up.
Old Nov 20, 2005 | 03:28 PM
phan's Avatar
have you tried a different ecu? or a known working distributor?
Old Nov 20, 2005 | 03:29 PM
RaysBoomBoomLude's Avatar
Did this happen RIGHT after you installed the motor?
Who did the wiring?
Check the Idle screw, trying screwing it out so itle set your base idle.
ALTHOUGH, Coolent Temp sensor should be adjusting your idle depending on the temp of the motor.
Did you burp the coolent system?
Old Nov 20, 2005 | 06:18 PM
SomeDude56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">anybody? i need to get this shitbox up and running.</TD></TR></TABLE>
Maybe if you talked nice to/about her she would run for you.
Old Nov 20, 2005 | 06:22 PM
mattie_96's Avatar
good point
Old Nov 20, 2005 | 07:21 PM
88YellowRexSi's Avatar
What about your fuel system? Clogged fuel filter? When you rev it she might just be short on fuel. Or is she just floodin out and runnin too rich? Check the condition of the plugs. Are they wet? Stock injectors or bigger? Is your TPS sensor adjusted correctly? Check to see that the TPS voltage increases smoothly from .5 volts to 4.5ish from closed to WOT. What ECU and what dizzy are you runnin? Check to see if the crank and the cam gears are lined up and that the t-belt didnt jump a tooth or two. Here's a few ideas for ya... hope it helps a lil.
mzaner
Dec 13, 2006 10:30 AM
fatexpletive
Jun 6, 2006 02:19 PM
mongoliandonuts
Sep 21, 2004 11:28 AM
quik1
Dec 19, 2003 03:32 PM
TheHatchHog
25
May 31, 2003 03:11 PM
