OBD0 B16a Into 93 Integra
Old Nov 20, 2005 | 05:00 AM
Novtecdohc's Avatar
Default OBD0 B16a Into 93 Integra
Im looking into getting a OBD0 B16a and swapping it into my 93 OBD1 Integra...
Im want to go with this motor because its cheaper... If im right, all i need to do is use my OBD1 Engine Harness, Get a OBD1 B16a Ecu and a OBD1 B16a Distributor right.. let me know..
Old Nov 25, 2005 | 03:36 AM
Katman's Avatar
Default Re: OBD0 B16a Into 93 Integra (Novtecdohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Novtecdohc &raquo;</TD></TR><TR><TD CLASS="quote">Im looking into getting a OBD0 B16a and swapping it into my 93 OBD1 Integra...
Im want to go with this motor because its cheaper... If im right, all i need to do is use my OBD1 Engine Harness, Get a OBD1 B16a Ecu and a OBD1 B16a Distributor right.. let me know..</TD></TR></TABLE>
yah you got it, also reuse/transfer your OBD1 4-wire 02 over to the OBD0 B16 too.
Old Nov 25, 2005 | 11:06 AM
Touge Tuning's Avatar
Default Re: OBD0 B16a Into 93 Integra (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">yah you got it, also reuse/transfer your OBD1 4-wire 02 over to the OBD0 B16 too.</TD></TR></TABLE>
i have a similar question, i wanna use an obd0 B18a1 in place of my obd2 B18b1 (running obd1 in a 98 civic) but im not sure what needs to be swapped over. On the back of the block it looks like the knock sensor has 2 pins instead of the single one on my B18b1, do i need to change this? If i just resuse the obd2a dizzy and an aftermarket IM should i be ok to use this engine for my buildup and sell the B18b1 ?
Old Nov 26, 2005 | 12:30 PM
Katman's Avatar
Default Re: OBD0 B16a Into 93 Integra (scarlemthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarlemthug &raquo;</TD></TR><TR><TD CLASS="quote">
i have a similar question, i wanna use an obd0 B18a1 in place of my obd2 B18b1 (running obd1 in a 98 civic) but im not sure what needs to be swapped over. On the back of the block it looks like the knock sensor has 2 pins instead of the single one on my B18b1, do i need to change this? If i just resuse the obd2a dizzy and an aftermarket IM should i be ok to use this engine for my buildup and sell the B18b1 ?</TD></TR></TABLE>
yeah, just swap over the OBD2 parts onto the B18A1 engine and you should be fine. Distributor, injectors, alternator, ecu, swap the KS if you can just to make it easier....but last I checked, LS ecu's don't look for a KS. I forget if the OBD2 LS ecu's look for the KS...hmm
Old Dec 3, 2005 | 03:55 AM
StorminMatt's Avatar
Just keep in mind that the B18A head and intake manifold is a downgrade vs the B18B stuff.
mynameizstitch
Jan 26, 2010 06:11 AM
HondaTeg95
Mar 17, 2005 12:16 PM
4ghatch
Nov 24, 2004 08:00 AM
byathread
Sep 15, 2003 02:11 PM
SiRex91
Sep 9, 2003 01:09 PM
