Stuck Ignition....HELP
Old Nov 20, 2005 | 12:18 AM
d15b7racer's Avatar
Default Stuck Ignition....HELP
on my daily driver.....1996 Civic LX.......the ignition is stuck/sticky. When i put in the key and try to turn it, its very hard to turn and sometimes doesnt. Its to the point where i cant even get it to turn over. i need to play with the key to get it to the on position and then jump the starter solenoid. Whats wrong with my ignition. Is it the key cylinder or the tumbler? what do i need to replace?
Old Nov 20, 2005 | 12:26 AM
E.Honda's Avatar
Default Re: Stuck Ignition....HELP (d15b7racer)
Try some graphite on the key....Work the key in and out a few times.
Old Nov 20, 2005 | 12:34 AM
d15b7racer's Avatar
Default Re: Stuck Ignition....HELP (E.Honda)
tried it already.....it did nothing....the key slides into the hole just fine.....its turning it from off to acc to on to crank thats the problem.
Old Nov 20, 2005 | 12:37 AM
E.Honda's Avatar
Is the key worn bad?
Old Nov 21, 2005 | 02:48 PM
d15b7racer's Avatar
no....i know its not the key. its the cylinder....like the actual part that turns.
minguswooten
Honda Civic (2001 - 2005)
Oct 8, 2021 07:46 AM
Tank_EM2
Aug 22, 2014 08:31 AM
D16A6Turbo
Apr 25, 2004 12:33 AM
Lude-Conduct
Nov 4, 2003 07:55 PM
