Just built a leakdown tool.. going to test tomorrow.. what to look for?
Old Nov 19, 2005 | 06:53 PM
92integraVTECgsr's Avatar
Default Just built a leakdown tool.. going to test tomorrow.. what to look for?
ok.. so I just built my own leakdown tool..
I was on c-speedracing, and read their article.. but just would like to clarify a few things.
If I can hear/feel air coming from the:
Oil Cap - ?
Oil Dipstick - ?
Radiator Cap - Headgasket
Bottom End - ?
Intake(throttle plate) - Intake Valves
Exhaust - Exhaust Valves and anything else????
What is wrong with the ones with the question mark.
Thanks everyone.
Old Nov 19, 2005 | 08:30 PM
Default Re: Just built a leakdown tool.. going to test tomorrow.. what to look for? (92integraVTECgsr)
no one has done a leakdown test?
Old Nov 19, 2005 | 08:41 PM
should the engine be warm or cold when doing this?
kchungb17a's Avatar
you're leaking through the rings if you're getting air from the oil cap/dipstick tube.
Engine should be warm. This poses a dilemma since you're not supposed to remove plugs on a warm engine but how you supposed to get it warm without plugs in it??? Just be careful when taking the plugs out.
Old Nov 19, 2005 | 08:52 PM
Default Re: Just built a leakdown tool.. going to test tomorrow.. what to look for? (kchungb17a)
ya i know.. ill be carefull with that.
a shop said that if i brought it in, that id need to leave it there so it could cool down???
Old Nov 19, 2005 | 09:14 PM
does each cylinder need to be set to TDC???
Old Nov 19, 2005 | 09:16 PM
PGK's Avatar
PGK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">does each cylinder need to be set to TDC???</TD></TR></TABLE>
TDC compression
Old Nov 19, 2005 | 11:31 PM
Default Re: Just built a leakdown tool.. going to test tomorrow.. what to look for? (PGK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PGK &raquo;</TD></TR><TR><TD CLASS="quote">TDC compression </TD></TR></TABLE>
what does that mean???
If I set Cylinder 1 to TDC, is that all I have to do? or do I have to set EACH cylinder to TDC???
Old Nov 20, 2005 | 11:21 AM
95 integra's Avatar
is it necessary to post the same damn thing twice????
Old Nov 20, 2005 | 11:22 AM
95 integra's Avatar
Default Re: Just built a leakdown tool.. going to test tomorrow.. what to look for? (95 integra)
BTW, you will hear atleast some air coming out of the engine...even if everything is in good condition.
Old Nov 20, 2005 | 05:49 PM
kchungb17a's Avatar
TDC of the compression stroke (all valves closed) vs exhaust stroke (all valves open... slightly)
kornkid21792
Feb 20, 2010 09:18 AM
Jackal6042
12
Jul 24, 2009 10:06 AM
blackeg
Nov 27, 2008 05:51 AM
92integraVTECgsr
Jan 3, 2006 03:41 AM
