SIR 1 problems after swap Wha happened ?
Old Nov 19, 2005 | 06:50 PM
SiR_Injected's Avatar
Default SIR 1 problems after swap Wha happened ?
i had my motor rebuilt!
installed in the car now all water lines are new ect prety well everything outside the motor
i just filled it up with 4/1/2 liters of oil went to turn it over OIL leaking huge cannt figure out why.. its no the cam seal or the dissy i checked! i dont seem to understang where all this oil has gone and why it would leak like that i need HELP
-Rob-
Old Nov 19, 2005 | 09:55 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: SIR 1 problems after swap Wha happened ? (dubz01si)
ok long shot here but please make sure that the head gasket is not upside down
Old Nov 19, 2005 | 10:37 PM
Default Re: SIR 1 problems after swap Wha happened ? (HOOKUPS)
really ? im assuming that this is a problem ill take off the head and flip it tomorrow! since its still new! you think that would make a difference ? cuz i didnt see any marking's ? its wet on the dissy side of the block not any ware else!
Old Nov 20, 2005 | 10:13 AM
DYNO-PRO
ok usually wet on the dizzy side is a leak from above (v-cover, cam seal , ect also check the large allens on the side of the head for tightness
Old Nov 20, 2005 | 06:22 PM
i just took of my valve cover
you know the allen key bolt's
the on on the side is okay on the dissy side.. there are 2 in line with the spark plugs at the top... the left side in front of engine beside the dissy is filled with oil & the other is dry ? problem ???
-Rob-
Old Nov 21, 2005 | 04:29 AM
now im being told it could be mis firing maybe the plugs in wrong order
Old Nov 21, 2005 | 06:09 AM
head gasket
im almost certain
Old Nov 21, 2005 | 06:29 PM
CURED!
91crx-jace
Apr 22, 2012 04:36 PM
blacktibby07
May 26, 2011 06:24 PM
BigDare23
13
Oct 15, 2010 03:02 PM
dartonh22
Aug 8, 2008 11:44 AM
em1gangsta
Mar 21, 2008 01:35 AM
